Setspeed() does not work !
# include<AccelStepper.h>
const int dirPin = 3;          // Pin which is used to accept the signal that determine the rotational speed of the motor
const int stepPin =2;         // Pin which is used to accept the pulse signal(one pulse corresponds to one step only)
float speed = 100;
AccelStepper myStepper(1,stepPin,dirPin);                    // Easy Driver mode
  //myStepper.setSpeed(100);
  myStepper.move(100);
  myStepper.setSpeed(speed);
  Serial.println(myStepper.speed());
    myStepper.runSpeed();
    Serial.print("CUS POS:");
    Serial.println(myStepper.currentPosition());
The speed of motor is always one, can any tell me what happen ?
What type of variable does setSpeed() take as a parameter ?
float or long ?
have you tried including setMaxSpeed() first in setup()?
Bear in my that if you are using a stepper motor, once it has reached myStepper.move(100); position the motor will stop moving.
You are printing inside function loop() with 9600 baud.
This is slowing down how fast function loop can loop
As a test comment out all serial printing
best regards Stefan
