Hey guys,
Got a potentiometer on the shield I'm using for a CompSci practical, which by default has the range 0-1023. However I need a range of 20-500.
How do I go about doing this?
Thanks,
Harry
Hey guys,
Thanks,
Harry
ThatAdamsGuy:
Hey guys,Got a potentiometer on the shield I'm using for a CompSci practical, which by default has the range 0-1023. However I need a range of 20-500.
Thanks,
Harry
To scale the value:-
val=map(potVal,0,1023,20,500);
(You can use the same variable for the result as the one used to read the pot if you want, too. I just used 'val' and 'potVal' to make it clearer.)
Edit: Or if you want to ignore values below 20 and above 500, use:-
val=constrain(potVal,20,500);
OldSteve:
To scale the value:-val=map(potVal,0,1023,20,500);
Hey, thanks for the response. I'm currently using
timeUnit = 10 + analogRead(POTENTIOMETER)
So instead would I want
timeUnit = map(analogRead(POTENTIOMETER), 0, 1023, 20, 500);
Thanks
ThatAdamsGuy:
Hey, thanks for the response. I'm currently usingtimeUnit = 10 + analogRead(POTENTIOMETER)
So instead would I want timeUnit = map(analogRead(POTENTIOMETER), 0, 1023, 20, 500);[/code]
Thanks
Yep. That scales the pot's 0-1023 to 20-500, whereas previously you would have been getting 10-1033.
This is linear mapping, which works for a linear potmeter.
If the potmeter is logarithmic you need another mapping function.
or you want to have something special you could use any transform function
timeUnit = convert(analogRead(POTENTIOMETER));
and the convert function is something like
int convert(int x)
return 255 + 255 * sin(x * 2 * PI / 1023.0);
int convert(int x)
if (x < 100) return 20;
if (x < 300) return 120;
if (x < 500) return 220;
if (x < 700) return 320;
return 500;
int convert(int x)
return 20 + random(min(x, 480));
or
