Here is the verbose result of my programming:
Sketch uses 5,298 bytes (16%) of program storage space. Maximum is 32,256 bytes. Global variables use 286 bytes (13%) of dynamic memory, leaving 1,762 bytes for local variables. Maximum is 2,048 bytes. /Users/fed/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino9/bin/avrdude -C/Users/fed/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino9/etc/avrdude.conf -v -patmega328p -cusbtiny -Uflash:w:/var/folders/lb/5zdjdm6153jcx_5nq32tt7gw0000gn/T/buildb926e4430d002b65d0ca44bda9d693e2.tmp/LED_strip_08.ino.hex:i
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:01:35 Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/ Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "/Users/fed/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino9/etc/avrdude.conf"
User configuration file is "/Users/fed/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : usb
Using Programmer : usbtiny
avrdude: usbdev_open(): Found USBtinyISP, bus:device: 006:003 AVR Part : ATmega328P Chip Erase delay : 9000 us PAGEL : PD7 BS2 : PC2 RESET disposition : dedicated RETRY pulse : SCK serial program mode : yes parallel program mode : yes Timeout : 200 StabDelay : 100 CmdexeDelay : 25 SyncLoops : 32 ByteDelay : 0 PollIndex : 3 PollValue : 0x53 Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : USBtiny
Description : USBtiny simple USB programmer, USBtinyISP - Inexpensive USB AVR Programmer
avrdude: programmer operation not supported
avrdude: Using SCK period of 10 usec avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.01s
avrdude: Device signature = 0x1e950f (probably m328p) avrdude: NOTE: "flash" memory has been specified, an erase cycle will be performed To disable this feature, specify the -D option. avrdude: erasing chip avrdude: Using SCK period of 10 usec avrdude: reading input file "/var/folders/lb/5zdjdm6153jcx_5nq32tt7gw0000gn/T/buildb926e4430d002b65d0ca44bda9d693e2.tmp/LED_strip_08.ino.hex" avrdude: writing flash (5298 bytes):
Writing | ################################################## | 100% 7.80s
avrdude: 5298 bytes of flash written avrdude: verifying flash memory against /var/folders/lb/5zdjdm6153jcx_5nq32tt7gw0000gn/T/buildb926e4430d002b65d0ca44bda9d693e2.tmp/LED_strip_08.ino.hex: avrdude: load data flash data from input file /var/folders/lb/5zdjdm6153jcx_5nq32tt7gw0000gn/T/buildb926e4430d002b65d0ca44bda9d693e2.tmp/LED_strip_08.ino.hex: avrdude: input file /var/folders/lb/5zdjdm6153jcx_5nq32tt7gw0000gn/T/buildb926e4430d002b65d0ca44bda9d693e2.tmp/LED_strip_08.ino.hex contains 5298 bytes avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 4.98s
avrdude: verifying ... avrdude: 5298 bytes of flash verified
avrdude done. Thank you.
