system
September 23, 2012, 2:21pm
1
hi there, I connect my several servoes to arduino, I use code that is below. if you can, tell whats wrong.
thanks
#include <Servo.h>
Servo myservo;
Servo myservo1;
int potpin = 0;
int val;
myservo.attach(9);
myservo1.attach(8);
val = analogRead(potpin);
val = map(val, 0, 511, 0, 40);
myservo1.write(val);
delay(1500);
val = map(val, 0, 511, 0, 0);
delay(1500);
myservo.write(val);
delay(1500);
myservo.write(val);
delay(1500);
system
September 23, 2012, 2:25pm
2
What is this supposed to do?
What do you want your code to do? What does it actually do?
How are you powering it all? Hopefully you have a separate power supply for the servos.
Riva
September 23, 2012, 2:29pm
3
myservo.write(val);
delay(1500);
This is repeated twice in the code
Edited to remove drivel
system
September 23, 2012, 2:36pm
4
The servo library doesn't require servos to be attached to PWM pins.
system
September 23, 2012, 2:44pm
5
lasha:
No idea what's wrong, because you haven't said.
Does it compile? Does it run? Does it do what you intend?
Riva
September 23, 2012, 2:50pm
6
AWOL:
Redacted.
Does Servo lib use it's own PWM then or are servo's controlled some other way?
system
September 23, 2012, 3:00pm
7
Yes. That is why using Servos reduces the number of PWM pins available. The Servo class co-opts the timers for controlling n servos. Each timer co-opted removes the ability to PWM two pins.
