Hello!
I have an RFID controlled cat flap, which consists of a few IR sensors, RFID decoding hardware and a flap actuated by a servo.
I need to use timer 1 for reading biphase encoded signals from RFID hardware, but I also need to use a servo. I currently use SoftwareSerial, but it's not great. I don't need the biphase decoder code and associated timer to run while the servo code runs, so I so I stop timer 1 and run servo.attach(N). Unfortunately it seems this doesn't work; Servo.h breaks when I use the same timer for anything else even when using detach() and attach(); the servo motor doesn't move at all.
Looking through the Servo library code, it appears to re-setup the timers whenever servo.attach(N) is called, so it should work, since my code isn't "overlapping" in its use of timer 1. My code is several large-ish files, so I've snipped out the relevant bits and attached here.
If anyone has any idea what's going on, I would appreciate your help! Thanks!
rfidControl.cpp
void rfidControl::setupRfidTimers(){
PRR &= ~(1 << PRTIM1); // Make sure Timer1 is enabled (Power Reduction Register)
TCCR1A = 0 ; // Normal counting mode
TCCR1B = B011 ; // Set clock bits
TCCR1B |= _BV(ICES1); // Edge Select: Trigger on rising edge
TIMSK1 |= _BV(ICIE1) | _BV(TOIE1); // enable input capture interrupt and overflow interrupt for timer 1
TCNT1=0;
void rfidControl::stop(){
rfid_state=STOP;
//stop RFID timers, all register bits are zero by default
TCCR1A = 0;
TCCR1B = 0;
TIMSK1 = 0;
bool rfidControl::checkAuth(){
//returns true if cat allowed through, false if not
ISR(TIMER1_CAPT_vect) {
//biphase decoder
catflap.ino
#include <Servo.h>
Servo flapServo;
setup(){
loop(){
if (rfidControl.checkAuth()){
rfidControl.stop();
openFlap();
rfidControl.setupRfidTimers();
openFlap(){
flapServo.attach(2);
delay(10);
flapServo.write(15);
delay(2000);
flapServo.write(118);
flapServo.detach();
