SPI really isn't that hard, if you want to, you can certainly do it, just replace
digitalWrite(latchPin, LOW);
shiftOut(dataPin, clockPin, MSBFIRST, shiftVal);
digitalWrite(latchPin, HIGH);
with
SPI.transfer(shiftVal);
Include the SPI library:
#include <SPI.h>
and add SPI.begin(); to your setup. If you want the maximum frequency, add SPI.setClockDivider(SPI_CLOCK_DIV2); after SPI.begin();
For example, a simple LED chaser animation:
<br>Code (ShiftOut):<br>
``` const uint8_t latchPin = 10; // Pin connected to ST_CP of 74HC595
const uint8_t clockPin = 13; // Pin 13 (SCK) connected to SH_CP of 74HC595
const uint8_t dataPin = 11; // Pin 11 (MOSI) connected to DS of 74HC595
const unsigned long delayTime = 100;
void setupcolor=#000000[/color] {
pinMode(latchPin, OUTPUT);
pinMode(clockPin, OUTPUT);
pinMode(dataPin, OUTPUT);
void loopcolor=#000000[/color] {
static uint8_t shiftVal = 1;
delaycolor=#000000[/color];
shiftVal = (shiftVal << 1) | (shiftVal == 0);
Code (SPI):[hr][/td][/tr][tr][td][size=9pt][tt][color=#5e6d03]#include[/color] [color=#434f54]<[/color][b][color=#d35400]SPI[/color][/b][color=#434f54].[/color][color=#000000]h[/color][color=#434f54]>[/color]
[color=#00979c]const[/color] [color=#00979c]uint8_t[/color] [color=#000000]latchPin[/color] [color=#434f54]=[/color] [color=#000000]10[/color][color=#000000];[/color] [color=#434f54]// Pin connected to ST_CP of 74HC595[/color]
[color=#434f54]// Pin 13 (SCK) connected to SH_CP of 74HC595[/color]
[color=#434f54]// Pin 11 (MOSI) connected to DS of 74HC595[/color]
[color=#00979c]const[/color] [color=#00979c]unsigned[/color] [color=#00979c]long[/color] [color=#000000]delayTime[/color] [color=#434f54]=[/color] [color=#000000]100[/color][color=#000000];[/color]
[color=#00979c]void[/color] [color=#5e6d03]setup[/color][color=#000000]([/color][color=#000000])[/color] [color=#000000]{[/color]
[b][color=#d35400]SPI[/color][/b][color=#434f54].[/color][color=#d35400]begin[/color][color=#000000]([/color][color=#000000])[/color][color=#000000];[/color]
[b][color=#d35400]SPI[/color][/b][color=#434f54].[/color][color=#d35400]setClockDivider[/color][color=#000000]([/color][color=#00979c]SPI_CLOCK_DIV2[/color][color=#000000])[/color][color=#000000];[/color] [color=#434f54]// 16 MHz / 2 = 8 MHz[/color]
[color=#d35400]pinMode[/color][color=#000000]([/color][color=#000000]latchPin[/color][color=#434f54],[/color] [color=#00979c]OUTPUT[/color][color=#000000])[/color][color=#000000];[/color]
[color=#000000]}[/color]
[color=#00979c]void[/color] [color=#5e6d03]loop[/color][color=#000000]([/color][color=#000000])[/color] [color=#000000]{[/color]
[color=#00979c]static[/color] [color=#00979c]uint8_t[/color] [color=#000000]shiftVal[/color] [color=#434f54]=[/color] [color=#000000]1[/color][color=#000000];[/color]
[color=#d35400]digitalWrite[/color][color=#000000]([/color][color=#000000]latchPin[/color][color=#434f54],[/color] [color=#00979c]LOW[/color][color=#000000])[/color][color=#000000];[/color]
[b][color=#d35400]SPI[/color][/b][color=#434f54].[/color][color=#d35400]transfer[/color][color=#000000]([/color][color=#000000]shiftVal[/color][color=#000000])[/color][color=#000000];[/color]
[color=#d35400]digitalWrite[/color][color=#000000]([/color][color=#000000]latchPin[/color][color=#434f54],[/color] [color=#00979c]HIGH[/color][color=#000000])[/color][color=#000000];[/color]
[color=#d35400]delay[/color][color=#000000]([/color][color=#000000]delayTime[/color][color=#000000])[/color][color=#000000];[/color]
[color=#000000]shiftVal[/color] [color=#434f54]=[/color] [color=#000000]([/color][color=#000000]shiftVal[/color] [color=#434f54]<<[/color] [color=#000000]1[/color][color=#000000])[/color] [color=#434f54]|[/color] [color=#000000]([/color][color=#000000]shiftVal[/color] [color=#434f54]==[/color] [color=#000000]0[/color][color=#000000])[/color][color=#000000];[/color]
[/size]
For a simple 8-LED chaser, you don't have to use SPI, but it will be faster (8 MHz clock vs a couple of KHz), and it will use a lot less CPU (the actual transmitting is done in hardware, rather than in software).
Pieter
