Hello team,
So today, i'm coming to check for some help & advice on how to debug my current project.
The simulator i'm using for this project : Clic on me!
I'm trying to create a specific target for a shooting range project - It will be down range at 25m, and a remote wired box will hold the 2 position switch that is in front of the shooter, on the table.
When the shooter starts it's cycle, he switches ON the switch & goes on until switching it to OFF.
We're changing the state of the target that is in front of the shooter by piloting a Servo motor betwen 0 & 90°.
So there's what the projet should do ![]()
- While the imput on pin 2 is HIGH (and stay's HIGH)
1: The target goes from 0° position (stand-by) to it's working position 90°
2: The target stay's at this 90° position for a random time that is betwen 2s & 8s
3: Once the random time is over, the target goes to it's stand-by position at 0° for random time betwen 2s & 8s
4: Once the random time is over, we start all this again.
This needs to work in a loop, the time the imput is HIGH.
As soon as the imput goes LOW, our target goes to it's stand-by position at 0° until the imput goes HIGH again.
I tried several way's to include my "process" into the loop, with IF's, ELSE's & IF ELSE conditions, but all the time i got stuck in one moment of the cycle, wich get unblocked by changing the switch position (From HIGH to LOW or LOW to HIGH).
Would you guy's maybe be kind enough to send me your though's & ideas ?
Thanks in advance.
#include <Servo.h>
Servo servo;
int buttonPin = 2; // Pin used for the digital input
int buttonState = 0; // State of the digital input
int previousButtonState = 0; // Previous state of the digital input
unsigned long changeTime = 0; // Time when the servo should change position
int currentPosition = 0; // Current position of the servo (0 or 90 degrees)
bool done = true;
servo.attach(9); // Attach the servo to pin 9
pinMode(buttonPin, INPUT); // Configure the pin for digital input
digitalWrite(buttonPin, HIGH); // Enable the internal pull-up resistor
randomSeed(micros()); // Initialize the random number generator with a value based on the micros() time at startup
buttonState = digitalRead(buttonPin); // Read the state of the digital input
if (buttonState != previousButtonState) { // If the state of the digital input has changed
if (buttonState == HIGH) { // If the digital input is in the HIGH position
servo.write(0); // Turn the servo to 0 degrees
changeTime = millis() + random(2000, 6000); // Calculate the time to change to position 90
done = false;
} else { // If the digital input is in the LOW position
servo.write(0); // Reset the servo to 0 degrees
done = true;
} else if (buttonState == HIGH && millis() >= changeTime && !done) { // If the state of the digital input has not changed
if (currentPosition == 0) { // MOVED from above: Already waited at position 0
servo.write(90); // Turn the servo to 90 degrees
changeTime = millis() + random(2000, 6000); // Calculate the time to change BACK to position 0
currentPosition = 90;
} else { // Already waited at some other position that is NOT zero
done = true; // Don't keep checking until flipped off and then back on
previousButtonState = buttonState; // Save the state of the digital input for the next iteration
