shooting target
Hi all
I'd welcome anyones input with this. Id like to build an air rifle / air pistol target which is able to sense where the target has been hit.
I've seen commercial products which use light barriers such as the link below, to form a kind of matrix as to where the pellet hit the barrier, but I am at a loss as to where I could find a similar type of sensor? I don't fancy trying to solder enough IRD's to form this type of resolution
https://www.meyton.info/en/produkte/messrahmen/black-magic/index.html
Again, thankyou for your thoughts
Thanks Delta :')
Why not buy that one?
it will be one the company has manufactured for their own use, and I'm not up for spending 800 on a target. This is afterall why we all tinker with arduinos to make things ourselves right? :slight_smile:
if I can find a premade sensor on the internet which serves the same purpose by all means il buy that
The sensor linked in the OP is claimed to have 192 independent light barriers. If the detector sells for $800, that is about $4 per barrier.
Considering the effort that went into the design and construction, that seems like an entirely reasonable price.
There was a very similar post a few months back, for paintballs IIRC. I suggested a matrix of print head type ribbon cables. Scratch off the coating where you want to make a matrix connection. Projectile impact does the job of a finger press on a regular keyboard. OP of that thread let it drop so nothing is known of the effectiveness of the idea.
