#include <EEPROM.h>
#include <SPI.h> // required by BnrOne.cpp
#include <BnrOneA.h>
#include <stdlib.h>
#include "Robot.h"
#include "NonLinearControl.h"
#include "IntersectionName.h"
#include "Intersection.h"
#include "Line.h"
#include "Path.h"
#include "Pitches.h"
#include "Music.h"
// Ideal Parameters: Speed 43
// Pause: 294
MoveType robotMove = MOVE_NORMAL; //! the type of Movement the robot is doing
Robot myRobot; //! the main Robot object
int detectFinish=0; //! flag to signal the end of the Maze
//! Print intersection in LCD
void printIntersection(IntersectionType intersectionType, MoveType robotMove)
if (robotMove != MOVE_NORMAL)
myRobot._one.lcd1(intersectionStr[intersectionType]);
//! Print path in LCD
\param path to be printed
\param lcd line where path is to be printed
void printPath(String path, int lcd)
char printThePath[path.length()+1];
for (unsigned int i=0 ; i < path.length() ; i++)
printThePath[i] = path[i];
printThePath[path.length()] = '\0';
if (lcd == 1)
myRobot._one.lcd1(printThePath);
myRobot._one.lcd2(printThePath);
//! Check if robot is at Finish line
bool isFinish (int &detectFinish)
detectFinish++;
if (detectFinish>=((110-myRobot._speed)/10))
return true;
return false;
// prints a count dounw in lcd2
void printCountDown()
myRobot._one.lcd2("***** 3 ******");
myRobot._one.lcd2("***** 2 ******");
myRobot._one.lcd2("***** 1 ******");
myRobot._one.lcd2("***** GO! ******");
delay(100);
// Print info on lcd: Exploring Maze or Direct to Goal
void printStep(bool mazeExplored)
if (!mazeExplored)
myRobot._one.lcd1(" Exploring Maze ");
myRobot._one.lcd1(" Shortest Path ");
printCountDown();
//! Setup functions call
Serial.begin(57600);
myRobot.init();
if ( myRobot._speed < 1 || myRobot._speed > 100)
myRobot._speed = 40; // set default working values
if ( myRobot._pause < 10 || myRobot._pause > 1000)
myRobot._pause = 300; // set default working values
printStep(false);
//! main loop function
//variables declarations
int button=0;
Line theLine;
Intersection intersection;
Intersection previousItersection;
Path exploredPath;
Path shortestPath;
bool mazeExplored = false;
while(true)
// read line pattern
myRobot._nonLinearControl._error = myRobot.readLineSensors(theLine.line) - 3500; //half of maximum value
theLine.lineADConvert();
theLine.setSignature();
// Check if the line signature is different from the previous or equal to N
if ( theLine.lineSignature != theLine.previousLineSignature ||
theLine.lineSignature =='N')
intersection.getIntersectionType(theLine.lineSignature);
robotMove = intersection.checkIntersection ();
if (mazeExplored)
if (robotMove == MOVE_FORWARD ||
robotMove == MOVE_LEFT ||
robotMove == MOVE_RIGHT||
robotMove == MOVE_TURN_ARROUND)
robotMove = intersection.checkIntersectionInPath (shortestPath);
theLine.previousLineSignature=theLine.lineSignature;
// if the line is a black bar check if it is the finish line
if (theLine.lineSignature == 'B')
if (isFinish(detectFinish))
myRobot._one.stop();
myRobot._one.lcd2("----FINISHED!---"); // send info to lcd
finishMusic(); // play finish music
delay(3000); // wait 3s
printPath(exploredPath.getPath(),1);// show explored path on lcd
shortestPath.getShortestPath(exploredPath);
printPath(shortestPath.getPath(),2);// show shortest path on lcd
mazeExplored = !mazeExplored; // toggle flag
while (button==0) button=myRobot._one.readButton(); // wait for button press
myRobot.Menu(); // show Menu
printStep(mazeExplored);
intersection.resetIntersection(); // reset intersection
detectFinish=0; // reset finish flag
exploredPath.setPath(""); // reset explored path
continue;
detectFinish=0;
// check if any button was pressed
if (button)
myRobot.Menu();
continue;
if (myRobot._debug) // check debug mode
printIntersection(intersection._intersectionType,robotMove);
char* emptyString=" ";
myRobot._one.lcd2 (theLine.lineBin,(unsigned char*)emptyString);
if(!myRobot.areThereObstacles()) // Check for obstacles
// detect a dead end
if (intersection == NONE && previousItersection == DEAD_END)
robotMove = MOVE_TURN_ARROUND;
intersection.setType(DEAD_END);
myRobot.sendToMotors(robotMove, theLine.lineSignature);
previousItersection = intersection;
exploredPath.updatePath(robotMove);
Hallo ich bin relativ neu beim Programmieren mit Arduino und habe diesen Code von der Internetseite botnroll.com von wo ich auch mein Arduino habe, nämlich das Arduino Uno. Allerdings zeigt der Code zwar nicht direkt einen Fehler an aber Shortest path wird nicht richtig ausgeführt.
