Show the Value of an INT on the Webserver
Is there a dead simple example somewhere that shows a webpage with just the number from an Unsigned int?
I'm using:
#include <WebSocketsServer.h>
#include <elegantWebpage.h>
#include <ESPAsyncWebServer.h>
I'm able to show and input date via input boxes etc from examples but really don't know enough about html or how it meshes with displaying variables on a webpage, specifically a number.
Here you go:
#include <ESP8266WiFi.h>
const char ssid[] = "mckinley_guest";
const char password[] = "redwoodcreek";
// Create an instance of the server
// specify the port to listen on as an argument
WiFiServer server(80);
  // Connect to WiFi network
  Serial.print(F("Connecting to "));
  Serial.println(ssid);
  WiFi.mode(WIFI_STA);
  WiFi.begin(ssid, password);
    Serial.print(F("."));
  Serial.println(F("WiFi connected"));
  // Start the server
  server.begin();
  Serial.println(F("Server started"));
  // Print the IP address
  // Check if a client has connected
  if (WiFiClient client = server.available()) {
    Serial.println(F("new client"));
    // Send the response to the client
    // it is OK for multiple small client.print/write,
    // because nagle algorithm will group them into one single packet
    client.print(F("HTTP/1.1 200 OK\r\nContent-Type: text/html\r\n\r\n<!DOCTYPE HTML>\r\n<html>\r\n"));
    unsigned int theAnswer = 42;
    client.print(theAnswer);
    Serial.println(F("Disconnecting from client"));
You can add a dynamic number like below, with the appropriate parts in initial conditions and the read and print in the body.
const int analogInPin = A0;
int sensorValue = 0;
            client.println("Analog pin A0 value is ");
            sensorValue = analogRead(analogInPin);
            client.println(sensorValue);
Thank you both!
You're welcome. I'm glad if I was able to be of assistance. Enjoy!
Per
