SIM 800L e sim WIND
Buon pomeriggio,
sto provando a connettere il mio modulo SIM800L alla rete GPRS senza alcun successo.
Il led indicante lo stato del modulino sembra lampeggiare nella modalità "Agganciato". A conferma di questo ricevo normalmente SMS.
Il problema risiede nell'agganciarlo alla rete.
utilizzo il seguente codice della libreria GSM:
// libraries
#include <GSM.h>
// PIN Number
#define PINNUMBER ""
// initialize the library instance
GSM gsmAccess;        // GSM access: include a 'true' parameter for debug enabled
GPRS gprsAccess;  // GPRS access
GSMClient client;  // Client service for TCP connection
// messages for serial monitor response
String oktext = "OK";
String errortext = "ERROR";
// URL and path (for example: arduino.cc)
char url[] = "arduino.cc";
char urlproxy[] = "http://www.arduino.cc";
char path[] = "/";
// variable for save response obtained
String response = "";
// use a proxy
boolean use_proxy = false;
  // initialize serial communications and wait for port to open:
  while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  use_proxy = false;
  // start GSM shield
  // if your SIM has PIN, pass it as a parameter of begin() in quotes
  Serial.print("Connecting GSM network...");
  if (gsmAccess.begin(PINNUMBER) != GSM_READY) {
    Serial.println(errortext);
    while (true);
  Serial.println(oktext);
  // read APN introduced by user
  char apn[50]="internet.wind";
  Serial.println(apn);
  // Read APN login introduced by user
  char login[50]=" ";
  Serial.print("login=");
  Serial.println(login);
  // read APN password introduced by user
  char password[20]=" ";
  Serial.print("password=");
  Serial.println(password);
  // attach GPRS
  Serial.println("Attaching to GPRS with your APN...");
  if (gprsAccess.attachGPRS(apn, login, password) != GPRS_READY) {
    // read proxy introduced by user
    char proxy[100];
    Serial.print("If your carrier uses a proxy, enter it, if not press enter: ");
    readSerial(proxy);
    Serial.println(proxy);
    // if user introduced a proxy, asks him for proxy port
    int pport;
    if (proxy[0] != '\0') {
      // read proxy port introduced by user
      char proxyport[10];
      Serial.print("Enter the proxy port: ");
      readSerial(proxyport);
      // cast proxy port introduced to integer
      pport = (int) proxyport;
      use_proxy = true;
      Serial.println(proxyport);
    // connection with arduino.cc and realize HTTP request
    Serial.print("Connecting and sending GET request to arduino.cc...");
    int res_connect;
    // if use a proxy, connect with it
    if (use_proxy) {
      res_connect = client.connect(proxy, pport);
      res_connect = client.connect(url, 80);
    if (res_connect) {
      // make a HTTP 1.0 GET request (client sends the request)
      client.print("GET ");
      // if use a proxy, the path is arduino.cc URL
      if (use_proxy) {
        client.print(urlproxy);
        client.print(path);
      client.println(" HTTP/1.0");
      client.println();
      // if you didn't get a connection to the server
    Serial.print("Receiving response...");
    boolean test = true;
    while (test) {
      // if there are incoming bytes available
      // from the server, read and check them
      if (client.available()) {
        char c = client.read();
        response += c;
        // cast response obtained from string to char array
        char responsechar[response.length() + 1];
        response.toCharArray(responsechar, response.length() + 1);
        // if response includes a "200 OK" substring
        if (strstr(responsechar, "200 OK") != NULL) {
          Serial.println("TEST COMPLETE!");
          test = false;
      // if the server's disconnected, stop the client:
      if (!client.connected()) {
        Serial.println("disconnecting.");
        client.stop();
        test = false;
  Read input serial
int readSerial(char result[]) {
  int i = 0;
  while (1) {
    while (Serial.available() > 0) {
      char inChar = Serial.read();
      if (inChar == '\n') {
        result[i] = '\0';
        return 0;
      if (inChar != '\r') {
        result[i] = inChar;
        i++;
Dalla seriale ottengo la seguente scritta:
Connecting GSM network...OK
internet.wind
login=
password=
ERROR
Ho verificato che la sim supportasse la 2G attraverso il mio smartphone
Sapreste indicarmi una possibile soluzione?
Grazie
