Sim 900 and pir sensor
Hi, guys, i cant make to send sms any pir event, pls help
#include <SoftwareSerial.h>
SoftwareSerial SIM900(7, 8);
String incomingData;
String message = "";
String stareAP = "";
String mesajPornire = "";
//int relay_pin = 12;
#define pirPin 11
int calibrationTime = 30;
long unsigned int lowIn;
long unsigned int pause = 5000;
boolean lockLow = true;
boolean takeLowTime;
int PIRValue = 0;
  delay(20000);
  Serial.begin(19200); // baudrate for serial monitor
  SIM900.begin(19200); // baudrate for GSM shield
  //pinMode(relay_pin, OUTPUT);
  pinMode(pirPin, INPUT);
  //digitalWrite(relay_pin, HIGH);
  SIM900.print("AT+CMGF=1\r");
  delay(100);
  SIM900.print("AT+CNMI=2,2,0,0,0\r");
  delay(100);
  mesajPornire = "Initializare aparat...";
  send_message(mesajPornire);
  receive_message();
  if (incomingData.indexOf("on") >= 0)
    message = "ONline";
    send_message(message);
    PIRSensor();
  if (incomingData.indexOf("off") >= 0)
    //digitalWrite(relay_pin, LOW);
    message = "OFFline";
  if (incomingData.indexOf("stare") >= 0)
   //String stareAP = "Activ";
void send_message(String message)
  SIM900.println("AT+CMGF=1");    //Set the GSM Module in Text Mode
  delay(100);
  SIM900.println("AT+CMGS=\"+4074141xxxx\""); // Replace it with your mobile number
  delay(100);
  SIM900.println(message);   // The SMS text you want to send
  delay(100);
  SIM900.println((char)26);  // ASCII code of CTRL+Z
  delay(100);
  SIM900.println();
void receive_message()
  if (SIM900.available() > 0)
    incomingData = SIM900.readString();
    Serial.print(incomingData);
    delay(10);
void PIRSensor()
    if(digitalRead(pirPin) == HIGH)
        if(lockLow)
            PIRValue = 1;
            lockLow = false;
            Serial.println("Motion detected.");
            message = "miscare detectata";
            delay(50);
        takeLowTime = true;
    if(digitalRead(pirPin) == LOW)
        if(takeLowTime)
            lowIn = millis();
            takeLowTime = false;
        if(!lockLow && millis() - lowIn > pause)
            PIRValue = 0;
            lockLow = true;
            Serial.println("Motion ended.");
            message = "fara miscare";
            delay(50);
What's the output of your code now? Isn't it behaving as you want it to? Are you getting SMS?
You are declaring this inside void receive_message()
Yes, I receive sms, the problem was that I don't receive when movement is detected
As Xfpd has pointed out, looks like there are some mistakes in your brackets. void receive_message() and void PIRSensor() are two different functions. But you have written void PIRSensor() inside void receive_message(). void receive_message() should be defined like the following:
    delay(10);
But you have missed the last bracket here and put it somewhere else. Please correct it.
