Greetings All,
I hope everyone is having a joyful Christmas season, and I wish you all good health and fortune in the future.
My problem:
I recently integrated a SIM7000A GSM module into my project. It can send and receive with no problems. Below is my code so you will see that when I send the "ON" command via text message, the SIM7000A is supposed to reply that the "Vehicle Starter ENABLED" which works flawlessly. It's actually much faster that the old SIM800 2G module that I was using. When I send the "OFF" command, again it works flawlessly.
But when I send the "GETLOC" command, I can see in the serial monitor that the SIM7000A received the command. and the LED lights up like it is supposed to, but the SIM7000A never replies back. I also ran some tests and attached the data in the serial monitor. I have two (2) SIM7000A modules that I tested with and it seems that they both work fine. I'm not very good at writing code, in fact I got lots of help from users right here on this forum for which I am forever grateful. I was forced to upgrade the module due to the 2G shutdown. Any help would be appreciated. I'm sure it's probably something stupid but I know very little about troubleshooting code. Thank you all in advance.
It seems to be breaking on this piece of code; GSM.print(pesan);
When this line is commented out, I get the demographics but no map or coordinates. It looks like this line of code works with this string; String pesan = "https://maps.google.com/?q=" + String(lati, 8) + "," + String(longi, 6);
Here is the SIM7000A that I'm using
And some pictures of the ACTUAL board.
CODE
#include <TinyGPS++.h>
#include <Wire.h>
#include <SoftwareSerial.h>
int thermistorPin = A0;
float R1 = 100000;
float R2, logR2, logR2Cube, tK, tC, tF;
float A = 1.958207e-03, B = 4.097654e-04, C = -21.767827e-07;
SoftwareSerial GSM(10, 11);
SoftwareSerial neo(8, 9);
String textMessage;
String lampState;
String weekday = "";
double lati = 0;
double longi = 0;
double speed = 0;
uint32_t direction = 0;
uint32_t num_sat = 0;
double elevation = 0;
#define redLed 3
#define greenLed 5
#define blueLed 6
#define fan 13
const int relay = 12;
TinyGPSPlus gps;
const int timezone_hours = -4;
const int timezone_minutes = 0;
int utcsecond = 0;
int utcminute = 0;
int utchour = 0;
int utcday = 1;
int utcmonth = 1;
int utcyear = 2021; // obviously wrong (I am writing this in the year 2024)
int localminute = 0;
int localhour = 0;
int localday = 1;
int localmonth = 1;
int localyear = 2021;
uint32_t daycount = 0;
pinMode(redLed, OUTPUT);
pinMode(greenLed, OUTPUT);
pinMode(blueLed, OUTPUT);
pinMode(relay, OUTPUT);
pinMode(fan, OUTPUT);
digitalWrite(fan, HIGH);
digitalWrite(redLed, HIGH);
digitalWrite(redLed, LOW);
digitalWrite(greenLed, HIGH);
digitalWrite(greenLed, LOW);
digitalWrite(blueLed, HIGH);
digitalWrite(blueLed, LOW);
digitalWrite(relay, LOW);
GSM.begin(9600);
neo.begin(9600);
GSM.listen();
delay(5000);
Serial.print("GSM ready...\r\n");
GSM.print("AT+CMGF=1\r\n");
GSM.print("AT+CNMI=2,2,0,0,0\r\n");
digitalWrite(fan, LOW);
delay(3000);
int Vout = analogRead(thermistorPin);
R2 = R1 * (1023.0 / Vout - 1.0);
logR2 = log(R2);
logR2Cube = pow(logR2, 3);
tK = (1.0 / (A + B * logR2 + C * logR2Cube));
tC = tK - 273.15;
tF = (tC * 9.0) / 5.0 + 32.0;
// Serial.print("Temperature: ");
// Serial.print(tF);
// Serial.println(" F");
// delay (1000);
if (tF > 100.0) {
// Serial.print("Temperature is: ");
// Serial.println("° F");
if (tF < 85.0) {
GSM.listen();
delay(2);
while (GSM.available() > 0) {
analogWrite(blueLed, 255);
analogWrite(redLed, 100);
textMessage = GSM.readString();
Serial.print(textMessage);
delay(10);
analogWrite(blueLed, 0);
analogWrite(redLed, 0);
neo.listen();
if (textMessage.indexOf("ON") >= 0) {
String array_string[20];
string_splitting(textMessage,array_string,'\"');
String NUMBER = array_string[1];
digitalWrite(relay, HIGH);
lampState = "ON";
Serial.println("Vehicle Starter ENABLED\r\n");
textMessage = "";
GSM.println("AT+CMGS=\"" + NUMBER + "\"\r");
GSM.print("Vehicle Starter ENABLED\r");
GSM.write(0x1a);
GSM.println("AT+CMGD=1,4");
delay(5000);
if (textMessage.indexOf("OFF") >= 0) {
lampState = "OFF";
Serial.println("Vehicle Starter DISABLED!\r\n");
textMessage = "";
GSM.print("Vehicle Starter DISABLED\r");
GSM.write(0x1a);
delay(5000);
if (textMessage.indexOf("GETLOC") >= 0) {
Serial.println("_____________________________________");
smartDelay(1000);
string_splitting(textMessage,array_string,'\"'); //
Serial.println("GPS data Recived\r\n");
textMessage = "";
speed = gps.speed.mph();
direction = gps.course.value();
num_sat = gps.satellites.value();
elevation = gps.altitude.feet();
Serial.print("Speed: ");
Serial.print(speed);
Serial.println(" Miles Per Hour");
Serial.print("Number of Satellites: ");
Serial.println(num_sat);
Serial.print("Raw course in 1/100 degrees = ");
Serial.println(direction);
Serial.print("Elevation: ");
Serial.print(elevation);
if (elevation > 0) Serial.println(" ASL");
if (elevation < 0) Serial.println(" BSL");
if (elevation = 0) Serial.println(" AT SEA LEVEL");
if (gps.time.isValid()) {
utcyear = gps.date.year();
utcmonth = gps.date.month();
utcday = gps.date.day();
utchour = gps.time.hour();
utcminute = gps.time.minute();
utcsecond = gps.time.second();
Serial.println("UTC = "+String(utchour)+":"+String(utcminute)+":"+String(utcsecond));
localyear = utcyear;
localmonth = utcmonth;
localday = utcday;
localhour = utchour + timezone_hours;
localminute = utcminute + timezone_minutes;
doLocalTimeCarries();
GSM.print("Date: ");
daycount = (localyear - 1601) * ((uint32_t)365);
daycount += (localyear - 1601) / 4;
daycount -= (localyear - 1601) / 100;
daycount += (localyear - 1601) / 400;
for (int i = 1; i < localmonth; i++) {
daycount += days_in_month(localyear, i);
daycount += localday;
switch (daycount % 7) {
case 0:
GSM.print("Sun ");
case 1:
GSM.print("Mon ");
case 2:
GSM.print("Tue ");
case 3:
GSM.print("Wed ");
case 4:
GSM.print("Thu ");
case 5:
GSM.print("Fri ");
case 6:
GSM.print("Sat ");
default:
GSM.print("Bad ");
GSM.print(localmonth);
GSM.print("/");
GSM.print(localday);
GSM.print("/");
GSM.println(localyear);
GSM.print("Time: ");
if (localhour < 10) GSM.print("0");
GSM.print(localhour);
GSM.print(":");
if (localminute < 10) GSM.print("0");
GSM.print(localminute);
GSM.print(":");
if (utcsecond < 10) GSM.print("0");
GSM.println(utcsecond);
GSM.print("Speed: ");
GSM.print(speed);
GSM.println(" MPH");
GSM.print("Direction: ");
// GSM.println(direction / 100.0);
if (direction < 1125) GSM.println("North");
else if (direction < 3375) GSM.println("NNE");
else if (direction < 5625) GSM.println("NE");
else if (direction < 7875) GSM.println("ENE");
else if (direction < 10125) GSM.println("East");
else if (direction < 12375) GSM.println("ESE");
else if (direction < 14625) GSM.println("SE");
else if (direction < 16875) GSM.println("SSE");
else if (direction < 19125) GSM.println("South");
else if (direction < 21375) GSM.println("SSW");
else if (direction < 23625) GSM.println("SW");
else if (direction < 25875) GSM.println("WSW");
else if (direction < 28125) GSM.println("West");
else if (direction < 30375) GSM.println("WNW");
else if (direction < 32625) GSM.println("NW");
else if (direction < 34875) GSM.println("NNW");
else GSM.println("North");
GSM.print("Number of Satellites: ");
GSM.println(num_sat);
GSM.print("Elevation: ");
if (elevation >= 0) {
GSM.print(elevation);
GSM.println(" Feet ASL");
else {
GSM.print(-elevation);
GSM.println(" Feet BSL");
GSM.print(pesan);
GSM.write(0x1a);
static void smartDelay(unsigned long ms) {
unsigned long start = millis();
do {
neo.listen();
delay(2);
while (neo.available())
gps.encode(neo.read());
} while (millis() - start < ms);
lati = gps.location.lat();
longi = gps.location.lng();
Serial.println(lati, 8);
Serial.println(longi, 6);
void string_splitting(String splitMsg, String bb[], char delimiter) {
int counter = 0 ;
for ( int i = 0 ; i < splitMsg.length() ; i ++ ) {
if ( splitMsg.charAt(i) == delimiter ) {
counter++;
else {
bb[counter] += splitMsg.charAt(i) ;
void doLocalTimeCarries() {
if (localminute < 0) {
localminute += 60;
localhour--;
else if (localminute >= 60) {
localminute -= 60;
localhour++;
if (localhour < 0) {
localhour += 24;
localday--;
else if (localhour >= 24) {
localhour -= 24;
localday++;
if (localday < 1) {
localmonth--;
if (localmonth < 1) {
localmonth += 12;
localyear--;
localday += days_in_month(localyear, localmonth);
else if (localday > days_in_month(localyear, localmonth)) {
localday -= days_in_month(localyear, localmonth);
localmonth++;
if (localmonth > 12) {
localmonth -= 12;
localyear++;
int days_in_month (int y, int m) {
if ((m==4)||(m==11)||(m==9)||(m==6)) return 30;
if (m!=2) return 31;
if ((y%400)==0) return 29; // leap year
if ((y%100)==0) return 28; // not a leap year
if ((y%4)==0) return 29; // leap year
SERIAL MONITOR DATA
GSM ready...
AT+CMGF=1
OK
AT+CNMI=2,2,0,0,0
OK
+CMT: "+12345678901",,"24/12/22,08:18:02-32"
ON
+CMT: "+12345678901",,"24/12/22,08:18:35-32"
ON
+CMT: "+12345678901",,"24/12/22,08:19:07-32"
OFF
AT+CNMI=2,2,0,0,0
OK
GSM ready...
AT+CMGF=1
OK
AT+CNMI=2,2,0,0,0
OK
+CMT: "+12162884282",,"24/12/22,09:54:32-32"
GETLOC
41.20671844
-81.974182
GPS data Received
Speed: 2.62 Miles Per Hour
Number of Satellites: 5
Raw course in 1/100 degrees = 0
Elevation: 1006.56 ASL
UTC = 17:54:35
AT+CMGD=1,4
OK
