SIM7600 HTTP AT Command Issues
Hello,
I am following the AT command manual for the SIM7600 to make a HTTP Request to my server, however It never connects to my server using the HTTP AT commands and nothing shows up on wireshark.
After: AT+HTTPACTION=1, i get OK, but then after the timeout i get a 714 error code (Connect socket failed)
I am unsure why
If i setup a TCP connection and use CIPSEND, it shows up in wireshark.
Here is my code:
void PostImage(const char *host, const char *resource, int port, const char *uuid, const char *name, uint8_t *payload,
               size_t length) {
    // start https
    Serial.println("Closing any previous HTTPS sessions");
    sendCommandWaitforMatch("AT+HTTPTERM", "OK");
    Serial.println("starting HTTPS...");
    ATCommandResponse started = sendCommandWaitforMatch("AT+HTTPINIT", "OK");
    Serial.println(started ? "HTTPS started" : "HTTPS start failed");
    if (!started) {
        return;
    //! look into caveat for this
    ATCommandResponse setUrl = sendCommandWaitforMatch(
        String(String("AT+HTTPPARA=\"URL\",\"") + "http://" + host + resource + ":" + port + "\"").c_str(), "OK",
        1000U);
    Serial.println(setUrl ? "HTTPS URL set" : "HTTPS URL set failed");
    ATCommandResponse setContentType =
        sendCommandWaitforMatch("AT+HTTPPARA=\"CONTENT\",\"multipart/form-data; boundary=----boundary\"", "OK");
    Serial.println(setContentType ? "HTTPS Content-Type set" : "HTTPS Content-Type set failed");
    ATCommandResponse setConnTimeout = sendCommandWaitforMatch("AT+HTTPPARA=\"CONNECTTO\",20", "OK");
    ATCommandResponse setRecTimeout = sendCommandWaitforMatch("AT+HTTPPARA=\"RECVTO\",10", "OK");
    //! 153600 max size
    //  image id
    //  total size
    String imageHead = String("----boundary\r\n") +
                       "Content-Disposition: form-data; name=\"image\"; "
                       "filename=\"PotWatcherImage.jpg\"\r\nContent-Type: image/jpeg\r\n";
    String imageIdHead = String("----boundary\r\n") + "Content-Disposition: form-data; name=\"imageId\"\r\n\r\n";
    String totalSizeHead = String("----boundary\r\n") + "Content-Disposition: form-data; name=\"totalSize\"\r\n\r\n";
    String tail = "\r\n----boundary--\r\n";
    // perform POST
    Serial.println("Performing HTTP POST request...");
    size_t body_size = imageIdHead.length() + String(name).length() + totalSizeHead.length() + String(length).length() +
                       imageHead.length() + length + tail.length();
    Serial.println(String("Sending length of: ") + body_size);
    ATCommandResponse startSend =
        sendCommandWaitforMatchRetry(String(String("AT+HTTPDATA=") + body_size + ",10000").c_str(), "DOWNLOAD");
    Serial.println(String("Start send: ") + String(startSend == ATCommandResponse::Status::OK));
    Serial.println("Sending Payload");
    sendString(imageIdHead.c_str());
    sendString(name);
    sendString(totalSizeHead.c_str());
    sendString(String(length).c_str());
    sendString(imageHead.c_str());
    uint8_t *fbBuf = payload;
    size_t remaining = length;
    while (remaining > 0) {
        size_t chunkSize = std::min(remaining, (size_t)TINY_GSM_RX_BUFFER);
        sendData(fbBuf, chunkSize);
        fbBuf += chunkSize;
        remaining -= chunkSize;
    Serial.println("Sending Tail");
    sendCommandWaitforMatch(tail.c_str(), "OK");
    ATCommandResponse sendRequest = sendCommandWaitforMatch("AT+HTTPACTION=1", "+HTTPACTION:", 20000U);
    ATCommandResponse readHead = sendCommandWaitforMatchRetry("AT+HTTPHEAD", "OK");
    // close https
    Serial.println("Close HTTPS session");
    ATCommandResponse close = sendCommandWaitforMatch("AT+HTTPTERM", "OK");
Output:
AT+HTTPTERM
OK
starting HTTPS...
AT+HTTPINIT
OK
HTTPS started
AT+HTTPPARA="URL","http://xx.x.xx.x/api/img:3000"
OK
HTTPS URL set
AT+HTTPPARA="CONTENT","multipart/form-data; boundary=----boundary"
OK
AT+HTTPPARA="CONNECTTO",20
OK
AT+HTTPPARA="RECVTO",10
OK
Sending length of: 280
AT+HTTPDATA=280,10000
DOWNLOAD
Start send: 1
Sending Payload
Sending Tail
----boundary
Content-Disposition: form-data; name="imageId"
----boundary
Content-Disposition: form-data; name="totalSize"
6
----boundary
Content-Disposition: form-data; name="image"; filename="PotWatcherImage.jpg"
hello␀
----bo
OK
AT+HTTPACTION=1
OK
+HTTPACTION: 1,714,0
AT+HTTPHEAD
ERROR
AT+HTTPHEAD
ERROR
AT+HTTPHEAD
ERROR
Close HTTPS session
AT+HTTPTERM
OK
