SIM800L vs SIM900
I have bought arduino uno today and i will try to make a device to transfer data to any server.
I will use a gsm shield to do this. I want to ask which gsm modem is compatible with arduino.
İ have seen many example with SIM900 but SIM800L is cheapest model.
Does SIM800L also compatible with arduino uno and if compatible which one you suggest to use.
Thank you.
Regardless of the SIM variant, get a shield. Many of the cheaper modules don't have voltage regulators or level shifters.
Sim800L works great with arduino, I've bought the cheaper model (http://www.ebay.com/itm/SIM-Board-SIM800L-GPRS-GSM-Module-Quadband-L-shape-Antenna-for-MCU-Arduino-/251929561356?hash=item3aa82c090c).
I don't know the difference between them, both are GSM (2G). I'm using it with arduino nano, but arduino uno is even better. There are examples in youtube about how to make the connections and the code.
Regards,
The AT-command-set is 99% identical for both modems (at least the commands you will use with an Arduino) so the same libraries will work.
// Per.
800 version is beter than 900 because 800 can work in all world. But 900 can`t. because 900 have missed some mH. I have business and I use this element around the world and some tests showing this. I offer to buy 800 version.
Hi guys! Which library are you using with an GSM800L?
Best
Petar
I want to calling a mobile number using SIM800L. what's the code? i need help
peshodenev:
Best
Petar
SIM800 and SIM900 are both quadband: 850, 900, 1800 and 1900 MHz.
SIM900 is older type (now obsolete), predecessor SIM800.
SIM800C has bluetooth on it,
SIM800L has FM on it.
SIM800F is pin compatible to SIM900 module.
SIM868 is dual sim version with GNSS and small form factor.
SIM800 use same AT commands as SIM900 + few new.
SIM900: http://simcomm2m.com/En/module/detail.aspx?id=71
SIM800: http://simcomm2m.com/En/module/detail.aspx?id=138
SIM800L: http://www.simcomm2m.com/phone/module/detail.aspx?id=13
SIM800C: http://simcomm2m.com/En/module/detail.aspx?id=74
SIM800F: http://simcomm2m.com/En/module/detail.aspx?id=130
SIM868: http://simcomm2m.com/En/module/detail.aspx?id=145
SIMCOM datasheets and firmware: http://simcom.ee/documents/
************** SIM900 vs SIM800 GSM MODULES****************
SIM800 series is the most compatible module and the most popular module in the world .
SIM900 was discontinued, SIM800 is a product developed by SIMCOM to replace SIM900, and it’s also the most mature and stable GSM module.
This article gives a brief description of the difference between SIM900 and SIM800 GSM modules.
https://www.hkfreecreate.com/sim800-vs-sim900/
