sim900 rain gauge
Hi friends,
I'm try to make a project with rain gauge, i set code for the rain gauge without sim900 and its work very will
this :
#include <Wire.h>
#include "RTClib.h"
RTC_DS3231 rtc;
const int REED = 9;              //The reed switch outputs to digital pin 9
int val = 0;                    //Current value of reed switch
int old_val = 0;                //Old value of reed switch
int REEDCOUNT = 0;
double RED = 0;//This is the variable that hold the count of switching
void setup(){
#ifndef ESP8266
  while (!Serial); // for Leonardo/Micro/Zero
#endif
 delay(3000); // wait for console opening
  if (! rtc.begin()) {
    while (1);
 rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));
 pinMode (REED, INPUT_PULLUP); //This activates the internal pull up resistor
void software_Reset() // Restarts program from beginning but does not reset the peripherals and registers
asm volatile ("  jmp 0");
void loop(){
 val = digitalRead(REED);      //Read the status of the Reed swtich
 DateTime now = rtc.now();
 if ((val == LOW) && (old_val == HIGH)){    //Check to see if the status has changed
   delay(10);                   // Delay put in to deal with any "bouncing" in the switch.
   REEDCOUNT = REEDCOUNT + 1;   //Add 1 to the count of bucket tips
   RED = (REEDCOUNT*0.2794);
   old_val = val;              //Make the old value equal to the current value
   Serial.print("Rainfall = ");
   Serial.println(RED);  //Output the count to the serial monitor
   Serial.println("mm");
    Serial.print(now.hour(), DEC);
    Serial.print(':');
    Serial.print(now.minute(), DEC);
    Serial.print(':');
    Serial.print(now.second(), DEC);
if((now.hour()== 0)&&(now.minute()== 0)) {
 software_Reset() ;
 else {
   old_val = val;              //If the status hasn't changed then do nothing
and i set the sim900 code without the rain gauge and its working normally
this one:
#include <SoftwareSerial.h>
SoftwareSerial gprsSerial(7, 3);
  gprsSerial.begin(19200);
  Serial.println("OFFAS is Conecting...");
  delay(2000);
  Serial.println("Done!...");
  gprsSerial.flush();
  Serial.flush();
  // attach or detach from GPRS service
  gprsSerial.println("AT+CGATT?");
  delay(100);
  toSerial();
  // bearer settings
  gprsSerial.println("AT+SAPBR=3,1,\"CONTYPE\",\"GPRS\"");
  delay(2000);
  toSerial();
  // bearer settings
  gprsSerial.println("AT+SAPBR=3,1,\"APN\",\"taif\"");
  delay(2000);
  toSerial();
  // bearer settings
  gprsSerial.println("AT+SAPBR=1,1");
  delay(2000);
  toSerial();
   // initialize http service
   gprsSerial.println("AT+HTTPINIT");
   delay(2000);
   toSerial();
delay(100);
   // set http param value
   gprsSerial.print("AT+HTTPPARA=\"URL\",\"http:/xxxxxx/xxxxx/write_data.php?");
   gprsSerial.print("data1=");
   gprsSerial.print("11");
   gprsSerial.print("&data2=");
   gprsSerial.print("66");
   gprsSerial.println("\"");
   delay(2000);
   toSerial();
   // set http action type 0 = GET, 1 = POST, 2 = HEAD
   gprsSerial.println("AT+HTTPACTION=0");
   delay(6000);
   toSerial();
   // read server response
   gprsSerial.println("AT+HTTPREAD");
   toSerial();
   gprsSerial.println("");
   gprsSerial.println("AT+HTTPTERM");
   toSerial();
   delay(300);
   delay(10000);
void toSerial()
  while(gprsSerial.available()!=0)
    Serial.write(gprsSerial.read());
but when I'm try to put them together it did not work and give me "0" on database
im try on this way
#include <Wire.h>
#include "RTClib.h"
RTC_DS3231 rtc;
int REEDCOUNT = 0;
  #ifndef ESP8266
#endif
    while (1);
  delay(2000);
  gprsSerial.flush();
  Serial.flush();
 delay(100);
  delay(100);
  toSerial();
 delay(100);
   toSerial();
   toSerial();
    toSerial();
   delay(100);
  delay(100);
  toSerial();
  // bearer settings
  delay(2000);
  toSerial();
  // bearer settings
  delay(2000);
  toSerial();
  // bearer settings
  delay(2000);
  toSerial();
   delay(2000);
   toSerial();
delay(100);
   gprsSerial.print("AT+HTTPPARA=\"URL\",\"http://xxxxxxx/xxxx/write_data.php?");
   gprsSerial.print(RED);  //Output the count to the serial monitor
   gprsSerial.print(now.hour(), DEC);
   delay(2000);
   toSerial();
   delay(6000);
   toSerial();
   toSerial();
   toSerial();
   delay(300)
   delay(10000);
void toSerial()
i will be very thankful if anyone can help me, because I'm try more than 5 way and all of it dose not work :cry:
