Does anyone know more about the SIM900A Extension Module GSM/GPRS 900/1800MHz Board Antenna Kit? I bought this from ebay and heard it might need to be flashed to be able to use outside China/Hong Kong/Philippines. Here's my thoughts about the pin configuration. The top 2 Vcc lines are for the Serial Output ports. They really don't need to be powered unless I'm using those ports. Not really sure what purpose they serve. I can still use the GSM module by powering VccMCU with 5V. Check out my board and please let me know your thoughts.
I connected the Pins VCC4,VCC5 and VCC_MCU together to my power supply with a Voltage of 4.1V. And GND of the module to the GND of my power supply.
Then I powered up the module and got a connection. If you send AT (CR+LF) yout get the answer "AT OK". It doesn't matter which baud rate you have selected because the module has auto baudrate detection.
My Module was locked and I had to flash the SIM900-Firmware on my SIM900A. The original firmware version on my module was: 1137B03SIM900A64_ST_ENHANCE
I'm not sure if there is a voltage regulator on this module!? How do you now that the module can handle a supply voltage of 5V on VCC4 and VCC5 ? (The range of the power supply for the SIM900 is 3.2V to 4.8V as specified in the SIM900 data sheet) I have no manual/datasheet for this module as mentioned earlier...
Okay, I asked my seller for more information about this module. Here is the answer:
the pin following:
GND -GND
SIMR---SIM900A RXD, TTL level, can not be directly connected to 232 level
SIMT---SIM900A TXD, TTL level, can not be directly connected to 232 level
RST---SIM900A reset, active low
VCC_MCU---when SIM900A module communicate with 5V TTL level, this pin is connected to DC 5V; when communicating with 3.3V TTL, this pin is connected to DC 3.3V.
VCC5 ---- DC 5V 1A input.
VCC4 ------ DC3.5--4.5V input,suit for lithium battery.
Note: Two-way power (VCC4, VCC5) connector(you can choose one):
When I connect 5V to VCC5 and VCC_MCU everything works fine. (VCC4 is open now)
Thanks for the help. I wonder if the reset pin is the same as NRESET mentioned in the article for flashing. I'll have to look at the schematics of the SIM900A modem.
I've also bought this board (but mini version v3.4.1) and have a question about usb to serial (ttl).
My USBSerial is cheap china one with 5v/3.3V/Tx/Rx/GND.
After connecting 3 pins Tx->SIMR RX->SIMT and GND to one GND pin, I cannot communicate with module itself.
Hi all, I've written up 2 Instructables that may be of interest to you involving my Sim900A Mini module v3.4...
and
A titbit Ive learned since then is that the Arduino IDE library "GSM" used GSMSoftwareserial for its serial comms and you cant use Softwareserial at the same time as the 2 are incompatible serial interfaces. Im investigating how to use the UNO hardware serial port now.
If you look at Category:SIM900 - ElectroDragon Wiki you will see that Australia ( and luckily for me ) all African countries are supported on the SIM900A.
On the mini 3.8.2 there are level converters on the back of the board, and a choice of 5v or 3v for the Rx and Tx lines, and the board runs on 5v.
