After learning so much from others posting on this forum, I decided to share my recent project. it is a simple differential steering robot that can be controlled from an Android phone via Bluetooth. The robot’s “brain” is DIY Arduino Uno compatible board. The robot uses a JY-MCU Bluetooth module for communication with an Android phone. A custom Android app, created with App Inventor 2 acts as a remote control, sending commands to the Arduino over Bluetooth that tell the robot to move forward, reverse, stop or rotate. Two HC-SR04 ultrasonic sensors (one mounted on the front and one on the back) are used for obstacle detection. If you try to drive the robot into a wall, it will override the command and stop when it gets closer than 10 cm.
More details and links to the Arduino sketch and the App Inventor project files below:
