idea behind this is for a simple 4 option arrow to point to the degrees relative to (incomingArr) which is giving a value of 0 to 360 to a home bearing point via Tinygps++
arrow to point North when the value is between 270 and 360 or 0 to 45
arrow to point East when the value is 45 to 135
arrow to point South when the value is 135 to 225
arrow to point West when the value is 225 to 315
been playing with greater but less than with a %% between but i get everything showing up or nothing....
if (incomingArr > 315 ) {ttgo->tft-> fillTriangle(165,70,225,70,195,10, TFT_GREEN)} //NORTH
if (incomingArr > 45 )ttgo->tft-> fillTriangle(165,70,165,30,225,50, TFT_RED) ; //EAST
if (incomingArr > 135 )ttgo->tft-> fillTriangle(165,30,225,30,195,90, TFT_RED) ;//SOUTH
if (incomingArr > 225 )ttgo->tft-> fillTriangle(225,30,225,70,165,50, TFT_GREEN) ;//WEST
Always best to post all your code, problems are often in the bit you dont post.
Also bear in mind that the course over ground that a GPS provides depends on movement, and at slow, say walking pace, can vary significantly as the position fix varies.
Thanks for taking the time to respond, the issue with using greater or less than is that the other lines are also displayed, the idea is only one arrow is presented when between a certain value..
The GPS point is set via a home point and bearing is relative back to that, and is equated on the travel direction so no mater the long and lat as long as your traveling towards the home point the up arrow will be displayed
