Simple code for clock
I am trying to edit some code that will display time for 5 minutes or so on 16 by 2 lcd display. The following code works only for a few seconds and resets after that. Is it possible to achieve this using Arduino without using any external module?
#include<LiquidCrystal.h>
int contrast=100;
int h=9;
int m=12;
int s=9;
int bl=10;
const int backlight=120;
static uint32_t last_time, now = 0;
LiquidCrystal lcd(12,11,5,4,3,2);
analogWrite(6,contrast);
lcd.begin(16,2);
analogWrite(bl,backlight);
now=millis();
 lcd.setCursor(0,1);
 lcd.print("Time ");
 if(h<10)lcd.print("0");
 lcd.print(h);
 lcd.print(":");
 if(m<10)lcd.print("0");
 lcd.print(m);
 lcd.print(":");
 if(s<10)lcd.print("0");
 lcd.print(s);
    for ( int i=0 ;i<4 ;i++)
  while ((now-last_time)<250)
    now=millis();
 last_time=now;
 s=s+1;
 if(s==60){
  s=0;
  m=m+1;
 if(m==60)
  m=0;
  h=h+1;
 if(h==13)
  h=1;
The Arduino can keep time and format it for a display using the Arduino Time library <TimeLib.h>.
However, it won't keep time very accurately, because the CPU clock is not particularly accurate. The Time library can be synchronized to external sources for accurate timekeeping.
Example:
//time library demo
#include <TimeLib.h>
  delay(2000); //wait for connection
  Serial.print("Setting clock to ");
  // set internal clock time and date.
//   setTime(hr,min,sec,day,mnth,yr);
   setTime(12,0,0,9,3,2024);
   print_date_time();
void print_date_time() { //easy way to print date and time
  char buf[40];
  sprintf(buf, "%02d/%02d/%4d %02d:%02d:%02d", day(), month(), year(), hour(), minute(), second());
  Serial.println(buf);
  static int minutes_past_midnight, last_print_time = 0;
  // check the clock
  minutes_past_midnight = hour() * 60 + minute(); //useful for alarms and timing functions
  // every minute, print the data and time
  if (minutes_past_midnight != last_print_time) {
    last_print_time = minutes_past_midnight;
    print_date_time();
Time keeping variables should be of type unsigned (uint32_t).
I think the for loop should be removed. What is it supposed to do?
For proper line out of your code press ctrl-t.
The following code works only for a couple of minutes. It resets after that. It appears that there is no way out.
#include <LiquidCrystal.h>
#include <Wire.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
unsigned long startTime; // Variable to store the start time
analogWrite(6,100);
  lcd.begin(16, 2);
  Wire.begin();
  startTime = millis(); // Save the start time
  // Calculate elapsed time since the start
  unsigned long elapsedTime = millis() - startTime;
  // Calculate current time
  int hour = (elapsedTime / 3600000 + 9) % 24; // Calculate hours, adding 9 hours for start time
  int minute = (elapsedTime % 3600000) / 60000; // Calculate minutes
  int second = (elapsedTime % 60000) / 1000; // Calculate seconds
  // Display the time on LCD
  lcd.clear();
  lcd.setCursor(5, 0);
  if (hour < 10) {
    lcd.print("0");
  lcd.print(hour);
  lcd.print(":");
  if (minute < 10) {
    lcd.print("0");
  lcd.print(minute);
  lcd.print(":");
  if (second < 10) {
    lcd.print("0");
  lcd.print(second);
  // Delay for one second
The last line of the loop is this:
Why have this when already using millis?
For my Arduino devices attempting time tracking without a Real Time Clock device, I have global variables for the hours, minutes, and seconds (unsigned ints). I use the “Blink Without Delay” example to update the time once per 1000 millis with a cascading series of if statements to handle the rollover for seconds, minutes, and hours in that order.
So, something like this:
// Arduino Time Code
/* code by jeremy as typed on a tablet from memory
Example use only. */
unsigned int secondCount = 0;
unsigned int minuteCount = 0;
unsigned int hourCount = 9;
unsigned long previousMillis = 0;
unsigned int secondInterval =1000;
	// <setup stuff here>
	if(currentMillis - previousMillis > secondInterval) {
		secondCount++;
		if(secondCount >59) {
			secondCount =0;
			minuteCount++;
			if(minuteCount >59) {
				minuteCount =0;
				hourCount++;
				if(hourCount >23) {
					hourCount =0;
					// <insert midnight tasks here>
This does not fit in an int. Add ul after the number.
Same here:
