Simple for loop not working i Arduino Uno R3
Here is my Sketch. I don't find any problem in it but it seems for loop is not working.
LED at pin 13 is continuously blinking. it is not stopping after 5 after it is program in for loop.
int ledPin=13;
int ontime=200;//2000ms on time for LED
int offtime=0500;//00ms off time for LED
int numBlink=5;//number of times LED to blink
pinMode(ledPin,OUTPUT);//set the pin mode to output type
  int i;// count variable
for(i=0; i<numBlink; i++){//run the following for i=0 to i=4
  digitalWrite(ledPin,HIGH);//set LED on
  delay(ontime);//wait for 1 sec
  digitalWrite(ledPin, LOW);//set LED off
  delay(offtime);//wait for 1 sec
What is the case for for loop for not stopping at count.
It does blink only 5 times . . . .
And then it blinks another only 5 times . . . .
Etc.
It keeps on looping the part under loop (funny, right?)
They really should include a note like " // put your main code here, to run repeatedly:" to let people know.
If you ONLY want it to blink 5 times and then do nothing at all after, like you only want it "to run once:" hint hint:
int ledPin=13;
int ontime=200;//200ms on time for LED
int offtime=500;//500ms off time for LED
for(int i=0; i<numBlink; i++){//run the following for i=0 to i=4
  delay(ontime);//wait for 200ms
  delay(offtime);//wait for 500ms
  // put your main code here, to run repeatedly. Nothing is here because you don't want to keep doing anything.
how to stop it
int ledPin = 13;
int ontime = 200; //2000ms on time for LED
int offtime = 0500; //00ms off time for LED
int numBlink = 5; //number of times LED to blink
  pinMode(ledPin, OUTPUT); //set the pin mode to output type
  for (i = 0; i < numBlink; i++) { //run the following for i=0 to i=4
    digitalWrite(ledPin, HIGH); //set LED on
  while(1){} // Go No further Stop here
if you only want this to run once you could also move it to the setup funciotn
int ledPin = 13;
Both changes will achieve your desired reault
Your problem is that you don't (seem to) understand that loop() is called repeatedly; no offense intended. So anything that you have placed in loop will be executed time after time.
You should, for what you want to achieve, basically forget that for- and while-loops exist and let loop() do the work.
  static byte flashcounter = 0;
  // check if we have done 5 flashes
  if(flashcounter < 5)
    // increment the counter
    flashcounter++;
I have replaced your variable 'i' by one called 'flashcounter'; just find it a bit clearer as it exactly reflects what it is used for.
The static keyword causes the value in the variable to be remembered between calls to loop().
If it really needs to run only once, use INTP's approach. The above approach has the advantage that it can easily be adjusted to react on a button press and flash 5 times again.
e.g.
    // increment the flash counter
    flashcounter++;
  // reset the flash counter on button press (button between pin and ground)
  if(digitalRead(yourButton) == LOW)
    flashcounter = 0;
You probably want to polish the last part a bit; e.g. only reset if flashcounter has reached 5.
For now, there is no need for debouncing as you're using two delays of one second. Once you change to the blink-without-delay approach, you will need to debounce the switch.
if you want to blink only for 5 times try
for(i; i<numBlink; i++)
don't put i=0 in the For loop , as it would always assign 0 to i at the end of each 5 cycles, then re initiate the for loop .
ishanch:
After early four years. How does one manage to dig up old threads without specifically searching for them because one has a problem?
