Simple midi encoder
Is anyone aware of a plan available to make a simple midi encoder
with an Arduino?
I want to have only one rotory encoder connected to an Arduino,
send midi information over usb cable to the computer
so that I can change the level on my music computer.
I did find this (see below links) which is exactly what I want but it uses a
very expensive Teensy LC board.
Is it possible to use another cheaper Arduino board?
My knowledge about Arduino is quite low but I have managed to
finish a couple of projects so far.
Any advice much appreciated.
MIDI on the ATtiny - mitxela.com
That's MIDI over UART only, not MIDI over USB.
He does have a USB variant (using V-USB), but this is very low-level. An even smaller, even sillier synth - mitxela.com
Edit: there's also this one: GitHub - mitxela/smsc
Here's a list of Arduino-compatible boards that support MIDI over USB: Control Surface: MIDI over USB
Thanks xfpd and PieterP
PieterP from the list of Arduino-compatible boards you gave, the Arduino Micro looks good or maybe the Arduino pro micro as it has a ATmega32U4 chip.
Its all a bit beyond me as the software from the Teensy LC board would need to be changed.
The pins layout is different. In theory if this was done, would it work?
If you use an example such as Control Surface: RotaryEncoder.ino, the code should be fairly portable, just change the pin numbers (while keeping in mind the available interrupt pins of the ATmega32U4).
I will order a couple of boards and encoders from
China and give it a go.
I appreciate the advice and link.
Thanks PieterP.
Davyd
