Hi all. This if my first post and one of my first arduino projects so go easy on me :D.
For now, i want to build a simple "high speed" timer.
ideally i would like the first digit to represent 0.01mS/ the second digit 0.1mS and so on. But so far the fastest i've managed to get the first digit clock speed is 1mS (using the delay command). is there anyway i can get a faster clock speed?
I will post the code as im guessing you are going to ask for it. The code is messy and far from perfect but it works. If there is a neater, easier way of coding this project im all open to good advice :). - the code is not commented, but it does work.
Thanks
#include "LedControl.h"
pin 12 is connected to the DataIn
pin 11 is connected to the CLK
pin 10 is connected to LOAD
We have only a single MAX72XX.
LedControl lc=LedControl(12,11,10,1);
unsigned long delaytime=1;
The MAX72XX is in power-saving mode on startup,
we have to do a wakeup call
lc.shutdown(0,false);
/* Set the brightness to a medium values */
lc.setIntensity(0,8);
/* and clear the display */
lc.clearDisplay(0);
int time = 0;
int s0 = 0;
int s1 = -1;
int s2 = -1;
int s3 = -1;
int s4 = -1;
int s5 = -1;
int s6 = -1;
int s7 = -1;
s0=time;
if (time==9){
time=-1;
if (s0==0){
s1=s1+1;
if (s1==10){
s1=0;
if (s1==0&&s0==0){
s2=s2+1;
if (s2==10){
s2=0;
if (s2==0&&s1==0&&s0==0){
s3=s3+1;
if (s3==10){
s3=0;
if (s3==0&&s2==0&&s1==0&&s0==0){
s4=s4+1;
if (s4==10){
s4=0;
if (s4==0&&s3==0&&s2==0&&s1==0&&s0==0){
s5=s5+1;
if (s5==10){
s5=0;
if (s5==0&&s4==0&&s3==0&&s2==0&&s1==0&&s0==0){
s6=s6+1;
if (s6==10){
s6=0;
if (s6==0&&s5==0&&s4==0&&s3==0&&s2==0&&s1==0&&s0==0){
s7=s7+1;
lc.setChar(0,0,s0 ,false);
lc.setChar(0,1,s1 ,false);
lc.setChar(0,2,s2 ,false);
lc.setChar(0,3,s3 ,false);
lc.setChar(0,4,s4 ,false);
lc.setChar(0,5,s5 ,false);
lc.setChar(0,6,s6 ,false);
lc.setChar(0,7,s7 ,false);
delay(delaytime);
time=time+1;
