Simple Waveform generator with Arduino Due -Cant compile
When I compile the code, it says,
"analogWriteResolution was not declared in this scope"
What is the problem? I'm attaching the code and the library which I compiled.
-Thushara Rathnayake
FunctionGenerator.ino (1.55 KB)
Waveforms.h (3.59 KB)
Did you tell the Arduino IDE that you have a Due?
In the future...
To post code and/or error messages:
  1. Use CTRL-T in the Arduino IDE to autoformat your complete code.
  2. Paste the complete autoformatted code between code tags (the </> button)
    so that we can easily see and deal with your code.
  3. Paste the complete error message between code tags (the </> button)
    so that we can easily see and deal with your messages.
  4. If you already posted without code tags, you may add the code tags by
    editing your post. Do not change your existing posts in any other way.
    You may make additional posts as needed.
  5. Please provide links to any libraries that are used
    (look for statements in your code that look like #include ). Many libraries
    are named the same but have different contents.
Before posting again, you should read the three locked topics at the top of the Programming Questions forum, and any links to which these posts point.
If your project involves wiring, please provide a schematic and/or a wiring diagram and/or a clear photograph of the wiring.
Good Luck!
Did you remember to select the DUE board before compiling?
I can upload the blink sketch successfully but when I try with the FunctionGenerator_Due.ino the following error comes. I haven't found a library zip file so I have copied and pasted the library code to a new tab and has named it "waveform.h"
Arduino: 1.6.12 (Windows 8.1), Board: "Arduino Due (Programming Port)"
In file included from C:\Users\User\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.11\cores\arduino/Arduino.h:44:0,
                 from sketch\FunctionGenerator_Due.ino.ino.cpp:1:
C:\Users\User\Documents\Arduino\FunctionGenerator_Due\FunctionGenerator_Due.ino\FunctionGenerator_Due.ino.ino: In function 'void loop()':
FunctionGenerator_Due.ino:37: error: 't_sample' was not declared in this scope
   sample = constrain(t_sample, 0, oneHzSample);
C:\Users\User\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.11\cores\arduino/wiring_constants.h:74:35: note: in definition of macro 'constrain'
 #define constrain(amt,low,high) ((amt)<(low)?(low):((amt)>(high)?(high):(amt)))
exit status 1
option enabled in File -> Preferences.
waveform.h (3.66 KB)
Perhaps
  sample = map(analogRead(A0), 0, 4095, 0, oneHzSample);
is supposed to be
  sample = constrain(sample, 0, oneHzSample);
Otherwise, what did you mean by t_sample ?
