Using the SimpleTime sketch for ESP32 I went in an adjusted the
parameter that defines which timezone is referenced.
Despite trying several different values the time always comes back
off by 7 hours. It says it is 7 hours ahead of my Central Time Zone time. Is there something I am not understanding?
#include <WiFi.h>
#include "time.h"
#include "sntp.h"
const char* ssid = "Homestead-LAN_EXT";
const char* password = "xxxxxxxxx";
const char* ntpServer1 = "pool.ntp.org";
const char* ntpServer2 = "time.nist.gov";
const long gmtOffset_sec = 3600;
const int daylightOffset_sec = 3600;
const char* time_zone = "CST6CDT,M3.2.0,M11.1.0"; // Central Time Zone value used from: https://sites.google.com/a/usapiens.com/opnode/time-zones
void printLocalTime()
struct tm timeinfo;
if(!getLocalTime(&timeinfo)){
Serial.println("No time available (yet)");
return;
Serial.println(&timeinfo, "%A, %B %d %Y %H:%M:%S");
// Callback function (get's called when time adjusts via NTP)
void timeavailable(struct timeval *t)
Serial.println("Got time adjustment from NTP!");
printLocalTime();
// set notification call-back function
sntp_set_time_sync_notification_cb( timeavailable );
* NTP server address could be aquired via DHCP,
* NOTE: This call should be made BEFORE esp32 aquires IP address via DHCP,
* otherwise SNTP option 42 would be rejected by default.
* NOTE: configTime() function call if made AFTER DHCP-client run
* will OVERRIDE aquired NTP server address
sntp_servermode_dhcp(1); // (optional)
* This will set configured ntp servers and constant TimeZone/daylightOffset
* should be OK if your time zone does not need to adjust daylightOffset twice a year,
* in such a case time adjustment won't be handled automagicaly.
configTime(gmtOffset_sec, daylightOffset_sec, ntpServer1, ntpServer2);
* A more convenient approach to handle TimeZones with daylightOffset
* would be to specify a environmnet variable with TimeZone definition including daylight adjustmnet rules.
* A list of rules for your zone could be obtained from https://github.com/esp8266/Arduino/blob/master/cores/esp8266/TZ.h
//configTzTime(time_zone, ntpServer1, ntpServer2);
//connect to WiFi
Serial.printf("Connecting to %s ", ssid);
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println(" CONNECTED");
delay(5000);
printLocalTime(); // it will take some time to sync time :)
