sizeof(<array>) does not work when array is declared like this
At least with Arduino sizeof(...) does not work if you declare an array like this:
const uint32_t m_arrayColorTable[]
Where you fill in the elements in the source file like so:
RGB(0, 0, 0),
RGB(5, 5, 5),
RGB(10, 10, 10),
RGB(15, 15, 15),
RGB(20, 20, 20),
RGB(25, 25, 25),
RGB(30, 30, 30),
RGB(35, 35, 35),
In CRainbow::begin()
 m_nArraySize = sizeof(m_arrayColorTable) / 4;
 Serial.print(sizeof(m_arrayColorTable));
 Serial.print(" ");
 Serial.println(m_nArraySize);
These output 0 as my array size.
The only way I can get non 0 is to put a value between the [] in the array declaration.
I am sure this is not a problem in Visual C++.
I am assuming this is a short coming in the compiler that Arduino is using.
So short of counting up how many array elements I actually have specified and then manually puting that number between the [] in the array declaration, is there some work around for this pest of a problem?
Color.cpp (9.49 KB)
Color.h (1.32 KB)
Common.h (2.06 KB)
Constants.h (119 Bytes)
CString.cpp (26.6 KB)
CString.h (9.63 KB)
Debug.cpp (19.5 KB)
Debug.h (4.76 KB)
RGBGardenLights.ino (888 Bytes)
boylesg:
RGB(0, 0, 0),
RGB(5, 5, 5),
RGB(10, 10, 10),
RGB(15, 15, 15),
RGB(20, 20, 20),
RGB(25, 25, 25),
RGB(30, 30, 30),
RGB(35, 35, 35),
Prove it. Post an MCVE that demonstrates the problem and doesn't involve downloading 9 files full of unrelated code.
Does not compile so I look forward to seeing you use it in a program that provides the proof of what you say
I have no trouble with
  Serial.println("Hello!");
#define RGB(nRed, nGreen, nBlue) (uint32_t)(((uint32_t)nGreen << 16) | ((uint32_t)nRed <<  8) | (uint32_t)nBlue)
#define GET_GREEN(nColor) (nColor & 0x00FF0000) >> 16
#define GET_RED(nColor) (nColor & 0x0000FF00) >> 8
#define GET_BLUE(nColor) nColor & 0x000000FF
#define WHITE (uint32_t)(((uint32_t)255 << 16) | ((uint32_t)255 <<  8) | (uint32_t)255)
#define RED (uint32_t)(((uint32_t)0 << 16) | ((uint32_t)255 <<  8) | (uint32_t)0)
#define YELLOW (uint32_t)(((uint32_t)255 << 16) | ((uint32_t)255 <<  8) | (uint32_t)0)
#define GREEN (uint32_t)(((uint32_t)255 << 16) | ((uint32_t)0 <<  8) | (uint32_t)0)
#define CYAN (uint32_t)(((uint32_t)255 << 16) | ((uint32_t)0 <<  8) | (uint32_t)255)
#define BLUE (uint32_t)(((uint32_t)0 << 16) | ((uint32_t)0 <<  8) | (uint32_t)255)
#define MAGENTA (uint32_t)(((uint32_t)0 << 16) | ((uint32_t)255 <<  8) | (uint32_t)255)
#define BLACK (uint32_t)0
#define MAX_COLORS 205
const uint32_t m_arrayColorTable[] =
RGB(0, 0, 0),
 RGB(5, 5, 5),
 RGB(10, 10, 10),
 RGB(15, 15, 15),
 RGB(20, 20, 20),
 RGB(25, 25, 25),
 RGB(30, 30, 30),
 RGB(35, 35, 35),
 RGB(30, 30, 30),
 RGB(35, 35, 35)
 size_t m_nArraySize = sizeof(m_arrayColorTable) / 4;
 Serial.print(" ");
What do you do that is different ?
Edit : I note you have not pre-pended the class name to the array filling declaration !!! Should it not be
const uint32_t CRainbow ::m_arrayColorTable[]
boylesg:
The Arduino IDE is using the gnu gcc compiler, so I'd be very surprised if something as basic as sizeof isn't working.
wildbill:
I'm astounded by the frequency with which "the compiler" is blamed in posts on this forum. I consider myself a moderately-experienced coder, learned 'C' in college about 35 years ago. I think the number of times I've honestly been able to blame a "compiler error" as the problem (verses a screw-up in my code) can be counted on one hand -- leaving out a few fingers. Even then, it was usually due to an incorrect option setting in the toolchain as opposed to a true error.
gfvalvo:
A couple of weeks ago someone reported a problem with a 'for' loop. It was definitely a compiler problem but that is the first one I have seen in a long long time.
This problem here seems to be that the OP has a class definition and a global definition of the array with the same variable name. He only initialises/fills the global definition but takes the sizeof the class definition.
Never mind it was a stupid error.
Forgot the CRainbow:: in const uint32_t CRainbow::m_arrayColorTable[] =
There were two copies of the array - one was a global variable and the empty one was a class member.
boylesg:
:slight_smile: As I pointed out !
