sizeof()
I have found a possible problem with sizeof(). Am I missing something?
My code:
#define PGM_ARD_SERIAL_BAUD 57600 //set Arduino usb serial port speed
String BOX_msg_1 = "this";
String BOX_msg_2 = "where 2nd non_blank msg would be";
String BOX_msg_3 = "123456789X12345";
Serial.begin(PGM_ARD_SERIAL_BAUD); //set Arduino usb serial port speed
Serial.print(F("size of msg 1: "));
Serial.println(sizeof(BOX_msg_1));
Serial.print(F("size of msg 2: "));
Serial.println(sizeof(BOX_msg_2));
Serial.print(F("size of msg 3: "));
Serial.println(sizeof(BOX_msg_3));
//output from above:
size of msg 1: 6
size of msg 2: 6
size of msg 3: 6
The results were the same for daily 1.8.6 for Aug 8 2018, and for stable 1.8.5
What are you expecting the value to be?
You are using a C++ 'String' object. The String object contains (at a guess) a pointer to a block of bytes (2 bytes), and an offset to the start and end (2 bytes each). This makes it fast to work with substrings of a string.
When you use sizeof, you get the size of the object, not the length of the actual string.
Generally, we avoid using C++ String objects when working on the arduino. Behind the scenes, it uses dynamically-allocated memory to do its work, and that's limited and prone to fragmentation. Instead, we usually use C-strings, which are arrays of byte terminated with a zero '\0'. The C programming language uses these by default, and there are a number of standard library functions which are designed to accept these - see the sticky post
Try this for more info:
char BOX_msg_1[] = "test";
char BOX_msg_2[4] = "test"; // warning! This won't be properly terminated!
char *BOX_msg_3 = "test";
msg_1 is an array of char. The C compiler allocates 5 bytes for it - 't' 'e' 's' 't' '\0'.
msg_2 is an array of char. We explicitly say it's 4 bytes, so a \0 terminator isn't put on it. If you use the library string functions (eg: strlen(), Serial.println()), they won't do as they are supposed to.
msg_3 is a pointer to char - 2 bytes. The compiler creates a 5-byte array of char, populates it with the text and its terminator, and puts the memory address of that array into the variable.
old_dog:
size of msg 1: 6
size of msg 2: 6
size of msg 3: 6
Are you expecting the following outputs? If so, please consult this link.
GolamMostafa:
which can be misleading if you are actually willing to count the number of symbols of course...
String msg1 = "今日は";
String msg2 = "hé";
  Serial.print("Length of the message1 = ");
  Serial.println(msg1.length());
  Serial.print("Length of the message2 = ");
  Serial.println(msg2.length());
void loop() {}
will show in the console
[sub][color=purple]Length of the message1 = [color=red][b]9[/b][/color]
Length of the message2 = [color=red][b]3[/b][/color]
[/color][/sub]
whereas I only see 3 and 2 symbols in my strings...
:grin: :smiling_imp:
