Sketch for Rain Sensor
No change!
I'll try your modified code, thanks.
I did think about writing the ASCOM driver myself and there are templates in Visual Studio but that's a whole new learning curve and I'm an astronomer not a programmer. I would rather be astronomying!
Thanks for your patience and tenacity.
Regards
Graeme
Well I tried it again using your modified code and the thing works perfectly! You are the man! With the switch open, the NINA Safety Monitor Is safe has a steady tick next to it and the Arduino D13 LED remains on. When the switch is closed, the LED turns off and the tick turns into a red X.
I understand the theory of INPUT_PULLUP but I haven't used it in the limited number of projects I've built. I'll read up on it to gain a thorough understanding.
I'll mark this thread as solution provided and then some!
I'm grateful for your help.
Thanks
Regards
Graeme
Well that's very good news. :grinning:
However, I don't understand why the external pull up of 10K you showed in your circuit diagram did not work equivalently to the INPUT_PULLUP mode. Perhaps there was a bad wire or connection.
This new code also removed some delays from the reading routine. Do you know how frequently the NINA/ASCOM code sends the "S#" message to the Arduino?
Perhaps some output buffer was getting filled up, or perhaps the reply was not coming back within a specified window, and one of these factors caused the program to reset the status.
Yes, I think the initial problem was having the IDE running at the same time as NINA caused a clash with Com 4, then the delays that were put in for fault finding were causing some sort of time out.
No worries. It's fixed now and I learnt a lot!
