Secondo voi riesco a far comparire i nomi che pare a me negli switch su NINA intervenendo sul codice? Non trovo il modo ammesso che ci sia.
Il mio dubbio è che venga definito nel driver.
// 30/08/2026
// D:\Lavori\ARDUINO\OSSERVATORIO_TEST\SWITCH_00
// https://github.com/Tigra-Astronomy/TA.ArduinoPowerController.AscomServer/tree/master
// Driver
// xx/xx/2026:
// Command reference
// :{S|R}{relaynum 0-7}{1=on, 0=off}#
// eg. :S00# = Set Relay 0 to OFF
// eg. :S01# = Set Relay 0 to ON
// eg. :R0# = Read status of relay 1, returns 0=Off, 1=On
// Tigra Astronomy
// Arduino code in controlling 8 relay switches
void SerialReceive();
const int SerialBufferSize = 6;
int relayArray [8] = {2, 3, 4, 5, 6, 7, 8, 9};
enum SerialState {start, wait, receive};
enum SerialState currentState = start;
char receiveBuffer [SerialBufferSize];
int bufferPosition = 0;
enum SerialState lastState = start;
// As per original sketch
//const int digital_on = 0;
//const int digital_off = 1;
// to handle relays which are reversed, swap these around eg XC-4418 (https://www.jaycar.com.au/medias/sys_master/images/images/9403712995358/XC4418-dataSheetMain.pdf)
const int digital_on = 1;
const int digital_off = 0;
for (int i = 0; i < 8; i++)
digitalWrite(relayArray[i],digital_off); // switch off relays by default
pinMode(relayArray[i], OUTPUT);
SerialStateMachine();
int DigitalReadOutputPin(int pin)
int bit = digitalPinToBitMask(pin);
int port = digitalPinToPort(pin);
if (port == NOT_A_PIN)
return -1;
return (*portOutputRegister(port) & bit) ? 0 : 1;
char ReadOneChar()
if (Serial.available() == 0)
return 0;
char rxByte = Serial.read();
//Serial.println(rxByte);
return rxByte;
void testMode()
for (int i = 0; i < 8; i++) //turn relays on
WriteRelayPin(relayArray[i], digital_on);
delay (250);
for (int i = 0; i < 8; i++) //turn relays off
WriteRelayPin(relayArray[i], digital_off);
delay (250);
void SerialStateMachine()
// if (currentState != lastState)
// Serial.print("State ");
// Serial.println(currentState);
lastState = currentState;
switch (currentState)
case start: SerialStart();
case wait: SerialWait();
case receive: SerialReceive();
void SerialStart()
ClearBuffer();
currentState = wait;
// Serial.println("SerialStart Initiated");
void ClearBuffer()
bufferPosition = 0;
for (int i =0; i < SerialBufferSize; i++)
receiveBuffer[i] = 0;
void SerialWait()
char rxByte = ReadOneChar();
if (rxByte != ':')
return;
ClearBuffer();
currentState = receive;
switch (rxByte)
case ':':
ClearBuffer();
case '#':
InterpretCommand();
case 0:
return;
default:
receiveBuffer[bufferPosition++] = rxByte;
void SendRelayStatus(int relay,int relayStatus)
Serial.print(':');
Serial.print(receiveBuffer[0]);
Serial.print(relay);
Serial.print(relayStatus);
Serial.print('#');
int GetRelayNumber()
char relay = receiveBuffer[1];
if (relay <'0' || relay > '7')
Serial.println("Bad relay number");
return -1;
int relayNumber = relay - '0';
return relayNumber;
void DoReadCommand()
if (bufferPosition != 2)
Serial.println("Wrong number of characters");
return;
int relay = GetRelayNumber();
if (relay <0) return;
int relayStatus = DigitalReadOutputPin(relayArray[relay]);
SendRelayStatus(relay,relayStatus);
void WriteRelayPin(int relayPin, int relayValue)
digitalWrite(relayPin, relayValue == digital_on ? digital_on : digital_off);
void DoSetCommand()
if (bufferPosition != 3)
return;
int relayPin = relayArray[relay];
int onOffCommand = receiveBuffer[2];
if (onOffCommand <'0' || onOffCommand > '1')
Serial.println("Bad data");
return;
//int relayValue = onOffCommand - '0';
int relayValue;
if (onOffCommand == '0' ? relayValue = digital_off : relayValue = digital_on);
WriteRelayPin(relayPin, relayValue);
SendRelayStatus(relay,relayValue);
void InterpretCommand()
// Serial.print("Received ");
// Serial.println(receiveBuffer);
switch (receiveBuffer[0])
case 's':
case 'S':
DoSetCommand();
case 'r':
case 'R':
DoReadCommand();
default:
Serial.println("Bad command");
