Sketch Problem With MCP Pot
I'm trying to write a simple to send a value to a dual pot MCP4261.
I keep get an error when I compile.
Can anyone point out my error
// include the SPI library:
#include <SPI.h>
// set pin 10 as the slave select for the digital pot:
const int slaveSelectPin = 4;
const int address = 0;
const int value = 255;
// set the slaveSelectPin as an output:
pinMode (slaveSelectPin, OUTPUT);
// initialize SPI:
SPI.begin();
void digitalPotWrite(int address, int value)
// take the SS pin low to select the chip:
digitalWrite(slaveSelectPin,LOW);
// send in the address and value via SPI:
SPI.transfer(address);
SPI.transfer(value);
// take the SS pin high to de-select the chip:
digitalWrite(slaveSelectPin,HIGH);
Where have you hidden the loop() function ?
It would help if you said what the error message is. I'll guess that it's something about a loop function not being defined.
Posting code snippets in code tags is good idea also.
Thanks for the snippet comment
Here's error msgs
C:\Users\LARIAN~1\AppData\Local\Temp\build8364529739229085721.tmp/core.a(main.cpp.o): In function main': C:\Program Files\Arduino\hardware\arduino\avr\cores\arduino/main.cpp:43: undefined reference to loop'
collect2: error: ld returned 1 exit status
Error compiling.
So, are you going to tell up where the loop() function is in your program ?
Lucky for you that I've got a spare loop() function that I don't need, so please feel free to add this to your sketch:
That should make your sketch compile, but it still won't work. Any guesses why?
Thanks for the spare loop - very kind to a newbie
And yes, I had a function defined in a function
Got it working
Thank you
