Sketch Re-configures I2C Display Address
Thus far, this is the code that most operates as I had hoped, however, at some point, the second seven segment display address gets configured mid-run, and stops working.
I'm not sure what/how to correct this. Is there an issue using an interrupt with I2C communication? Or is it my method for displaying the values/interfacing with the display? I guess I'm kind of at a loss as to where to begin.
I'm using the Sparkfun I2C 4 digit seven segment displays, in addition to a push button attached to Di/o 2.
 * This code is designed to calculate the flow and volume of fluid through an Omega FTB-432 flow meter
 * This code utilizes interrupts to determine the pulses from the flow meter, then calculates the volume and flow
 * Code to be added will include the means to display flow and volume on a pair of 4 digit seven segment
 * displays utilizing an i2c interface.
#include <Wire.h>
#define gallon 51//45
unsigned long pulseTime[2];
int buttonPin = 2;
volatile byte state = LOW;
//int timer = 0;
int pulseCounter = 0;
int pulseCount = 0;
//int count[2];
int galCount = 0;
int resetPin = 3;
int systemState = 2;
int controlPin = 10;
byte flowDigits[3];
byte volumeDigits[3];
int userStart = 0;
  Wire.begin(); //Join i2c Bus
  Wire.beginTransmission(0x71);
  Wire.write(0x76);
  //Wire.write(0b00000001);
  Wire.endTransmission();
  Wire.beginTransmission(0x72);
  Wire.write(0x76);
  pinMode(buttonPin, INPUT_PULLUP);
  attachInterrupt(digitalPinToInterrupt(buttonPin),pulse,RISING);
  pinMode(controlPin, OUTPUT);
  while(galCount < 3 == true){
    if(pulseCounter < gallon == true){
        Serial.print("Number of pulses: ");Serial.println(pulseCounter);
        unsigned char flowRate = (((float)pulseCounter)/ ((float)millis() - (float)pulseTime[0]));
        Serial.print("Flow Rate: ");Serial.print(flowRate);Serial.println(" gpm");
        unsigned char volume = (((float)pulseCounter) / ((float)gallon)) + (galCount);
        Serial.print("Volume: ");Serial.print(volume);Serial.println(" Gallons");
        //i2c
        float flo0 = ((float)pulseCount/(float)gallon);
        int val0 = (int) (10 * (int)flo0);
        float flo1 = (((float)flo0*10) - (float)val0);
        int val1a = (int) ((100*(int)flo0));
        int val1b = (int) (10 * (int)flo1);
        int val1 = (int)val1a + (int)val1b;
        float flo2 = ((((float)pulseCount/((float)millis()-(float)pulseTime[0])) * (100)) - ((int)val1));
        float vol0 = ((float)pulseCount/(float)gallon);
        int valf0 = (int) (10 * (int)vol0);
        float vol1 = (((float)vol0*10) - (float)valf0);
        int valf1a = (int) ((100*(int)vol0));
        int valf1b = (int) (10 * (int)vol1);
        int valf1 = (int)valf1a + (int)valf1b;
        float vol2 = ((((float)pulseCount/(float)gallon) * (100)) - ((int)val1));
        //byte volumeDigits[3];//values[3];
        volumeDigits[0] = (int)vol0;
        volumeDigits[1] = (int)vol1;
        volumeDigits[2] = (int)vol2;
        flowDigits[0] = (int) flo0;
        flowDigits[1] = (int) flo1;
        flowDigits[2] = (int) flo2;
        Wire.write(0x76);
        Wire.write(0x77);
        Wire.write(volumeDigits[0]);
        Wire.write(volumeDigits[1]);
        Wire.write(volumeDigits[2]);
        Wire.write(0x76);
        Wire.write(0x77);
        Wire.write(flowDigits[0]);
        Wire.write(flowDigits[1]);
        Wire.write(flowDigits[2]);
    }else{
      Serial.println("Gallon incremented");
      galCount++;
      Serial.print("Number of Gallons: ");Serial.println(galCount);
      pulseCounter = 0;
      delay(100);
  if(galCount >= 3 == true){
    //digitalWrite(outputLED, HIGH);
    systemState = 1;
    digitalWrite(controlPin, LOW);
    Serial.println("Fluid at 3 gallon capacity");
    do{
      //Serial.println("Fill complete");
      Wire.write(0x76);
      Wire.write('F');
      Wire.write('i');
      Wire.write('L');
      Wire.write('L');
      delay(10);
      Wire.write(0x76);
      Wire.write('D');
      Wire.write('o');
      Wire.write('n');
      Wire.write('E');
      delay(10);
      //systemState = 0;
    }while(systemState = 1);
void pulse(){
  state = !state;
  pulseTime[1] = pulseTime[0];
  pulseTime[0] = millis();
  pulseCounter++;
  pulseCount++;
Post a wiring diagram of your complete setup.
    do{
      Wire.write(0x76);
      Wire.write('F');
      Wire.write('i');
      Wire.write('L');
      Wire.write('L');
      delay(10);
      Wire.write(0x76);
      Wire.write('D');
      Wire.write('o');
      Wire.write('n');
      Wire.write('E');
      delay(10);
      //systemState = 0;
That do-while-loop will run forever as systemState is not modified inside the loop.
pulseCount and pulseCounter should be declared volatile as well (as state already is).
The delay(10) calls before Wire.endTransmission() can be eliminated, they are not needed. The data will be sent in the endTransmission() method and not in the write() method anyway.
