On the Q forum there were issues about not being able to use the Adafruit ST7796 library, which I have a fix for and submitted a PR to Adafruit. Since my display has
a capacitive touch display I thought I would try to get it to work as well. For this latest test of this, I installed the Adafruit_FT6206 library and started off with
their CapTouch_onoffbutton example sketch and switched all of the references
from ILI9341 to ST7796S and built it using IDE 2.3.7 and also then updated the
mapping of X, Y from touchscreen to match this setup, which working.
Current code:
//This example implements a simple sliding On/Off button. The example
// demonstrates drawing and touch operations.
//Thanks to Adafruit forums member Asteroid for the original sketch!
#include <Adafruit_GFX.h>
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_ST7796S.h>
#include <Adafruit_FT6206.h>
// The FT6206 uses hardware I2C (SCL/SDA)
Adafruit_FT6206 ts = Adafruit_FT6206();
#define TFT_DC 4
#define TFT_CS 2
#define TFT_RST 3
Adafruit_ST7796S tft(TFT_CS, TFT_DC, TFT_RST);
boolean RecordOn = false;
#define FRAME_X 210
#define FRAME_Y 180
#define FRAME_W 100
#define FRAME_H 50
#define REDBUTTON_X FRAME_X
#define REDBUTTON_Y FRAME_Y
#define REDBUTTON_W (FRAME_W/2)
#define REDBUTTON_H FRAME_H
#define GREENBUTTON_X (REDBUTTON_X + REDBUTTON_W)
#define GREENBUTTON_Y FRAME_Y
#define GREENBUTTON_W (FRAME_W/2)
#define GREENBUTTON_H FRAME_H
void drawFrame()
tft.drawRect(FRAME_X, FRAME_Y, FRAME_W, FRAME_H, ST77XX_BLACK);
void redBtn()
tft.fillRect(REDBUTTON_X, REDBUTTON_Y, REDBUTTON_W, REDBUTTON_H, ST77XX_RED);
tft.fillRect(GREENBUTTON_X, GREENBUTTON_Y, GREENBUTTON_W, GREENBUTTON_H, ST77XX_BLUE);
drawFrame();
tft.setCursor(GREENBUTTON_X + 6 , GREENBUTTON_Y + (GREENBUTTON_H/2));
tft.setTextColor(ST77XX_WHITE);
tft.setTextSize(2);
tft.println("ON");
RecordOn = false;
void greenBtn()
tft.fillRect(GREENBUTTON_X, GREENBUTTON_Y, GREENBUTTON_W, GREENBUTTON_H, ST77XX_GREEN);
tft.fillRect(REDBUTTON_X, REDBUTTON_Y, REDBUTTON_W, REDBUTTON_H, ST77XX_BLUE);
drawFrame();
tft.setCursor(REDBUTTON_X + 6 , REDBUTTON_Y + (REDBUTTON_H/2));
tft.setTextSize(2);
tft.println("OFF");
RecordOn = true;
void setup(void)
tft.init(320, 480);
if (!ts.begin(40)) {
Serial.println("Unable to start touchscreen.");
else {
Serial.println("Touchscreen started.");
tft.fillScreen(ST77XX_BLACK);
// origin = left,top landscape (USB left upper)
tft.setRotation(1);
redBtn();
// See if there's any touch data for us
if (ts.touched())
// Retrieve a point
TS_Point p = ts.getPoint();
uint16_t tmp = p.x;
int x = p.y;
int y = tft.height() - tmp;
if (RecordOn)
if((x > REDBUTTON_X) && (x < (REDBUTTON_X + REDBUTTON_W))) {
if ((y > REDBUTTON_Y) && (y <= (REDBUTTON_Y + REDBUTTON_H))) {
Serial.println("Red btn hit");
redBtn();
else //Record is off (RecordOn == false)
if((x > GREENBUTTON_X) && (x < (GREENBUTTON_X + GREENBUTTON_W))) {
if ((y > GREENBUTTON_Y) && (y <= (GREENBUTTON_Y + GREENBUTTON_H))) {
Serial.println("Green btn hit");
greenBtn();
Serial.println(RecordOn);
I then created a new App (Foo) in Applab and copied these sources into
sketch.ino. Note I edited the sketch.yaml as well to point to my modified
version of the ST77 library: like:
profiles:
default:
fqbn: arduino:zephyr:unoq
platforms:
- platform: arduino:zephyr
libraries:
- MsgPack (0.4.2)
- DebugLog (0.8.4)
- ArxContainer (0.7.0)
- ArxTypeTraits (0.3.1)
- dir: /home/arduino/libraries/Adafruit-ST7735-Library
- dir: /home/arduino/libraries/BitBang_I2C
- dependency: Adafruit BusIO (1.17.4)
- Adafruit GFX Library (1.12.4)
- FT6236G (1.0.0)
default_profile: default
It failed to build as I had not yet added the Adafruit_FT6206 library to the project.
Which I then did and then tried to run it again and it brought a lot of other libraries
and failed to build:
tarting app "foo"
Sketch profile configured: Name="default", Port=""
The library Adafruit BusIO has been automatically added from sketch project.
The library Adafruit FT6206 Library has been automatically added from sketch project.
The library Adafruit GFX Library has been automatically added from sketch project.
The library Adafruit ILI9341 has been automatically added from sketch project.
The library Adafruit SH110X has been automatically added from sketch project.
The library Adafruit ST7735 and ST7789 Library has been automatically added from sketch project.
The library Adafruit STMPE610 has been automatically added from sketch project.
The library Adafruit TSC2007 has been automatically added from sketch project.
The library Adafruit TouchScreen has been automatically added from sketch project.
The library ArxContainer has been automatically added from sketch project.
The library ArxTypeTraits has been automatically added from sketch project.
The library DebugLog has been automatically added from sketch project.
The library MsgPack has been automatically added from sketch project.
/home/arduino/.arduino15/internal/Adafruit_ILI9341_1.6.2_7e00cb0d7f19934d/Adafruit ILI9341/Adafruit_ILI9341.cpp:51:10: fatal error: pins_arduino.h: No such file or directory
51 | #include "pins_arduino.h"
compilation terminated.
exit status 1
In particular the Adafruit_ILI9341 library was installed, and has not yet been
modified to work with Zephyr.
Why did it do this? Because the Adafruit FT6206 Library says it depends on GFX and ILI9341 libraries. Note: their source files have no dependency on these, however their examples do. And the Adafruit_ILI9341 library says it depends on
STMPE610...
The issue is caused by how Applab is doing the library dependency processing.
It went ahead and tried to build the source files for ILI9341, yet nothing in our
simple project depends on it.
Note: So on other sketch I went to using the FT6236G library by Bitbank2, which
I needed to update a supporting library BitBang_I2C to run on Q (zephyr boards)
PR issued.
Not sure what to do here for the Adafruit library
