My problem is that this code sometimes works exactly like I want it to and jumps from state 0 to state 4 to alarmsetstate 0 -> alarmsetstate 1 -> alarmsetstate 2. But sometimes it jumps over certain states and I can't figure out why.
The interrupt is set to trigger when rising, how is it then possible that it skipes a state while only being pressed once?
Another problem is that after some time the program gets stuck when the display is showin on or off (alarmsetstate 2).
Does anybody know how I can resolve these two problems.
I'm just starting with arduino coding and am quite a noob, so please be gentle.
Thanks in advance for your help.
#include <Adafruit_SSD1306.h>
#include <Adafruit_GFX.h>
#define OLED_RESET 4
Adafruit_SSD1306 display(OLED_RESET);
int state = 0;
int alarmsetstate = 0;
int Button1 = 2;
int Button2 = 3;
int h = 7; //standard alarm time hour
int m = 30; //standard alarm time minutes
int alarmstartm = 0; //minutes variable for beginning increase light
int alarmstarth = 7; //hours variable for beginning increase light
int alarm = 0;
int alarmlength = 30; //amount of minutes in advance of real alarm time
int delaytime = 200;
pinMode(Button1,INPUT);
pinMode(Button2,INPUT);
attachInterrupt(digitalPinToInterrupt(2),setAlarm,RISING);
display.begin(SSD1306_SWITCHCAPVCC, 0x3C);
if(state==0) //Display time
display.clearDisplay();
display.setTextSize(4);
display.setTextColor(WHITE);
display.setCursor(0,0);
display.print("TIME");
display.display();
else if(state==4){ //Set alarm time
if(alarmsetstate==0){ // Set hours
display.print(h);
display.print(":");
display.print(m);
display.display();
if(digitalRead(Button2)==1){ //Set hours of alarm
h=h+1; //increase by 1 hour
if(h==24){ //if its 24 hour reset hour to 0
h=0;
delay(delaytime);
else if(alarmsetstate==1){ // Set minutes
display.print(h);
display.print(":");
display.print(m);
display.display();
if(digitalRead(Button2)==1){ //Set minutes of alarm
m=m+5; //increase alarmtime by 5 min
if(m==60){ // if min equals 60 reset to zero
m=0;
delay(delaytime);
else if(alarmsetstate==2){ // Set if alarm is ON or OFF
if(alarm==1){
display.print("ON");
else{
display.print("OFF");
display.display();
if(alarm==1){alarm = 0;}
else{alarm = 1;}
delay(delaytime);
else{ // If alarmsetstate doesn't equal one of the declared values
display.setTextSize(1);
display.println("E:alarmstate= ");
display.print(alarmsetstate);
display.display();
else if(state==5){
alarmstartm = m - alarmlength; //Begin alarmlengt earlier than setalarm
alarmstarth = h;
if(alarmstartm<0){ //if alarmstart is less than 0 set 1 hour back
alarmstartm = 60 + alarmstartm;
alarmstarth = alarmstarth - 1;
alarmsetstate=0; //reset alarmsetstate to zero
state = 0; //Go back to displaying current time (state 0)
else{ //If state doesn't equal one of the declared values
display.print("E: state= ");
display.print(state);
display.display();
void setAlarm(){
if(state==0){
state=4;
else if(state==4){
alarmsetstate=1;
alarmsetstate=2;
state=5;
else{
display.print("E: interrupt ");
display.display();
void Nightlight(){
