sleep and ext. interrupt help (files added)
Hello everyone,
What do I want to do?
--> Arduino starts sleeping mode.
--> It wakes up when the digital pin 2 (int 0) pressed(triggered push button) and wait signals any buttons.
--> until the signal comes any button, Arduino does nothing.
-->after any button is pressed, arduino does the orders and then it sleeps again.
Thank you in advance :slight_smile:
sample.zip (101 KB)
Cross post:
http://forum.arduino.cc/index.php?topic=437004.msg3011218
Try this,
    #include <avr/sleep.h>
    int wakePin = 2;                 // pin used for waking up
    int led=13;
    void wakeUpNow() {
      // execute code here after wake-up before returning to the loop() function
      // timers and code using timers (serial.print and more...) will not work here.
      // we don't really need to execute any special functions here, since we
      // just want the thing to wake up
      pinMode(wakePin, INPUT_PULLUP);
      pinMode(led, OUTPUT);
      attachInterrupt(0, wakeUpNow, LOW); // use interrupt 0 (pin 2) and run function wakeUpNow when pin 2 gets LOW
    void sleepNow() {
        set_sleep_mode(SLEEP_MODE_PWR_DOWN);   // sleep mode is set here
        sleep_enable();          // enables the sleep bit in the mcucr register
        attachInterrupt(0,wakeUpNow, LOW); // use interrupt 0 (pin 2) and run function
        sleep_mode();            // here the device is actually put to sleep!!
        // THE PROGRAM CONTINUES FROM HERE AFTER WAKING UP
        sleep_disable();         // first thing after waking from sleep: disable sleep...
        detachInterrupt(0);      // disables interrupt 0 on pin 2 so the wakeUpNow code will not be executed during normal running time.
      digitalWrite(led, HIGH);
      digitalWrite(led, LOW);
      sleepNow();     // sleep function called here
i want to do that. i tried many times these code. it's just only sleep and awake thing. i need a different solution. thanks for reply.
