Sleep mode arduino pro micro
Im using an arduino pro micro and i would like to use the sleep mode.
I used the lowpower library with an exemple code.
But when i uploaded this code, i can't access to the Serial monitor in order to verify if it works.
Did you know why ?
Thank you for your help.
#include <LowPower.h>
void lowPowerSleep(int minutes)
  int seconds = minutes * 60;
  int sleeps = seconds / 8;
  for (int i = 0 ; i < sleeps ; i++) {
    LowPower.powerDown(SLEEP_8S, ADC_OFF, BOD_OFF);
  lowPowerSleep(1);
  Serial.println("HELLO");
of course wont!
according the the code you posted, your arduino will be put to sleep BEFORE it even gets to the Serial.print point.
also the other thing that I don't understand is you "lowPowerSleep" routine... why do you have a 'for' loop to repeatedly call the 'powerDown' functions.... IMHO it only needs to be called ONCE at which point the sleep(powerdown) process would be triggered.
kindly please study your code a bit more....
The Pro Micro does USB in the main processor. If you put that in power-down sleep mode, almost everything is deactivated, the USB subsystem too. So you loose the USB connection and you're responsible to activate that again, once you wake up. If you immediately print something to that system it will be lost. Your operating system must handle a lost and reconnect correctly to be able to get anything from that device too.
Hello,
Thank you for your answers.
The maximum time for the arduino sleeping with the lowpower library is 8s. So if i want to sleep during 10 minutes for exemple i need to make a loop right ? My RTC cant deliver any external pulse to wake up the arduino.
I set the Serial.print before putting the arduino to sleep. The objective is to wake up the arduino after a minute and print a "hello". After one minute, the arduino LED flashes but nothing is printed on the serial monitor. Is it because I need to wait longer or add something?
  delay(2000);
  lowPowerSleep(1);
  //delay(1000);
I guess you receive that on the PC, but only the print before the Micro sleeps for the first time. After that I guess you should at least call
USBDevice.attach();
to re-initialize the USB subsystem. I never tried it myself but that may be already sufficient.
Why do you put an USB connected device to sleep? Doesn't make sense to me.
Hello,
Thank you for your answer. It is for try if the arduino wakes up properly.
At the end, my main objective is to write on the sd card some datas every 10 minutes.
I will try to write datas on my sd card after the arduino sleeps.
Then connect a USB2Serial adapter to the D0/D1 pins and use Serial1 for debugging. The UART is available almost immediately after wake-up.
Getting USB serial ready after a sleep is not worth the effort if it's used only for debugging.
Remember: you have to find a solution on your PC too, once you fixed the Arduino problem. If you're using Windows there, I cannot help.
Here is an example of using software serial comms between to 2 arduinos where one always sleeps until it receives a wakeup LOW pulse from other arduino.
sleepy arduino:
//Sleeping arduino
When the arduino is in SLEEP_MODE_PWR_DOWN the only way to wake it is with either
 - a watchdog timer interrupt,
 - a level interrupt on pins 2 or 3, or
 -  a Pin Change interrupt
#include <avr/sleep.h>
#include <SoftwareSerial.h>
#define RXPIN 2
#define TIMEOUT 1000UL
SoftwareSerial mySerial(RXPIN, 4); //pin2 RX, pin4 TX
unsigned long oldtime = 0;
void wakeUpNow()        // here the interrupt is handled after wakeup
  sleep_disable();         // first thing after waking from sleep:
  // disable sleep...
  detachInterrupt(digitalPinToInterrupt(RXPIN));      // disables interrupt 0 on pin 2 so the
  Serial.println("Woken!");
  sei();
  mySerial.begin(9600);
  mySerial.print("w"); //tx 'w' so indicate device in awake and ready to receive
  oldtime = millis();
  while (millis() - oldtime < TIMEOUT) { //wait for 1000ms for sender to reply
    if (mySerial.available()) {
      char c = mySerial.read();
      if (c == 'W') {
        Serial.println("WakeUp Acknowledged!");
  if (millis() - oldtime > TIMEOUT){
    sleepNow();
void sleepNow() {
  sleep_enable();
  set_sleep_mode(SLEEP_MODE_PWR_DOWN);
  /* Trigger mode of the interrupt pin. can be:
                   LOW        a low level triggers
                   CHANGE     a change in level triggers
                   RISING     a rising edge of a level triggers
                   FALLING    a falling edge of a level triggers
       In all but the IDLE sleep modes only LOW can be used.
  Serial.println("Sleeping Now");
  mySerial.end();
  attachInterrupt(digitalPinToInterrupt(RXPIN), wakeUpNow, LOW); // wakeUpNow when pin 2 gets LOW
  sleep_mode();
  pinMode(RXPIN, INPUT_PULLUP);
  if (millis() - oldtime < TIMEOUT) { //go to sleep if no data received by TIMEOUT
      oldtime = millis();
      Serial.println(c); //print RX data in serial monitor (as ASCII)
  else {
    mySerial.print("s"); //tells sender it is going to sleep
    sleepNow();
waking arduino
SoftwareSerial mySerial(11, 12);
void sendData() {
  char data[9] = "abcdefgh";
  for (char i = 0; i < 8; ++i) {
    mySerial.print(data[i]);
    delay(50);
  Serial.println("READY");
  char otwp;
    otwp = mySerial.read();
    Serial.println(otwp);
  if (otwp == 'w') {
    mySerial.print("W");
    sendData();
  if (millis() - oldtime > 5000) { //send a 2ms LOW pulse (wakeup command)
    digitalWrite(12, LOW);
    delay(2); //at least 2ms LOW is required to cause other arduino to wake up
    digitalWrite(12, HIGH);
    oldtime = millis();
hope that helps...
Actually the serial monitor is deactivated and does not reactivate itself. It's not important in my case because I want to access the serial monitor during the initialization to calibrate my weight sensor. However, it writes to my SD card every minute.
#include <SPI.h>
#include <SD.h>
File myFile;
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  Serial.print("Initializing SD card...");
  SD.begin(4);
  if (!SD.begin(4)) {
    Serial.println("initialization failed!");
    while (1);
  Serial.println("initialization done.");
  myFile = SD.open("toto.txt", FILE_WRITE);
  if (myFile) {
    myFile.println("testing 1, 2, 3.");
    myFile.close();
  delay(2000);
  lowPowerSleep(1);
  //delay(1000);
Does it write to the SD card? I would expect the file being extended by one line each 56 seconds.
Yes, the arduino wrote on the sd card "testing 1, 2, 3." each minutes
I dont know if that was your question.
You can find my code with an application on weight sensor in this post.
So, that wasn't your problem. Unfortunately I have no clue what your problem is. Describe in detail what behavior you expect and what you get.
