Hello there,
It is my first project with Arduino on the ESP-01 bord.
I'm trying to use ESP-01 as a lapcounter in my digital slotcar track.
It is basicly a log of level changes handled by interrupt-routines and
sent via WiFi to my computer, where I detect, make up and display the results.
I was quite happy to get it run, but unfortunately there are a very few events missing,
which is of course not acceptable during race.
I assume, they are lost because of handling the interrupts during WiFi comunications.
I stoped working on it for a while, but then I found hints using the 'ICACHE_RAM_ATTR'-Macro.
for shifting the code into different RAM having a better performance.
Can somebody help me to get this done?
When I insert 'ICACHE_RAM_ATTR' at my sketch, I get a message like:
... was not declared in this scope.
Thank you in advance!
Here is my Code:
#include <ESP8266WiFi.h>
const char* ssid = "GP-Alsterdorf";
const char* password = ""; // "" = kein Passwort erforderlich
int Ereigniszaehler = 1;
long int StartMicros;
String AntwortLog = "";
String Header = "";
String Komando = "";
WiFiServer server(80); // erzeuge eine Instanz des Servers auf Port 80
// Ein/Ausgabe Pins vorbereiten
pinMode(0, OUTPUT);
pinMode(1, INPUT_PULLUP); //Empfängerdiode Rechte Spur (Anschlußbezeichnung TXD)
pinMode(2, OUTPUT); //Spannungsversorgung der Lichtschranken in den Slots
digitalWrite(2,1); //Spannungsversorgung der Lichtschranken in den Slots ausschalten
pinMode(3, INPUT_PULLUP); //Empfängerdiode Linkee Spur (Anschlußbezeichnung RXD)
attachInterrupt(digitalPinToInterrupt(1), InterruptroutineRechteSpur, CHANGE);
attachInterrupt(digitalPinToInterrupt(3), InterruptroutineLinkeSpur, CHANGE);
delay(1);
// AccessPoint einrichten
WiFi.mode(WIFI_AP);
WiFi.softAP(ssid, password);
server.begin();
WiFiClient client = server.available(); // Prüfe, ob Client verbunden ist
if (!client) {return;}
yield();
Komando = client.readStringUntil('\r'); // Komandostring vom Client lesen
if (Komando.indexOf('CLEAR') != -1){ // Falls Komandostring 'CLEAR' enthält
AntwortLog = ""; // Daten im AntwortLog löschen
if (Komando.indexOf('GO') != -1) { // Falls Komandostring 'GO' enthält
StartMicros = micros(); // us-Zählerstand merken
Ereigniszaehler = 1; // Ereigniszaehler initialisieren
digitalWrite(2,0); // Spannungsversorgung für Lichtschranken in den Slots einschalten
client.flush(); // Warten bis alle Zeichen gesendet wurden
yield();
Header = "HTTP/1.1 200 OK\r\n"; // Formatierung des Headers für Antwort an Client
Header += "Content-Length: ";
Header += AntwortLog.length(); // Länge des AntwortLog einfügen
Header += "\r\n";
Header += "Content-Type: text/html\r\n";
Header += "Connection: close\r\n";
Header += "\r\n";
yield();
client.print(Header); // Antwort-Header senden
client.print(AntwortLog); // AntwortLog senden
client.stop(); // Client stoppen
//void InterruptroutineLinkeSpur() {
void ICACHE_RAM_ATTR InterruptroutineLinkeSpur() {
// Verarbeitung eingehender Pegeländerungen am Eingang GPIO 3 (linke Spur) //
AntwortLog += Ereigniszaehler;
AntwortLog += ",L,";
AntwortLog += micros() - StartMicros;
AntwortLog += ",";
AntwortLog += digitalRead(3);
AntwortLog += "\r";
Ereigniszaehler ++;
void InterruptroutineRechteSpur() {
// Verarbeitung eingehender Pegeländerungen am Eingang GPIO 2 (rechte Spur) //
AntwortLog += ",R,";
AntwortLog += ",";
AntwortLog += digitalRead(1);
AntwortLog += "\r";
Ereigniszaehler ++;
