Hi all,
Im trying to make a program. It will control five axis driven by steppers. The steppers should all reach there final position at the same time independet off how far they have to travel. Right now i do this by calculating the biggest amount of steps a motor have to do. And then i calculate how many steps each motor have to do for each step of the biggest move. This is done by using the map function which seem to make the code very slow and therefore i cannot rotate the motors as fast as i want.
do you have any suggestion on how to simplify it or other solution?
edit:you should look at the code under the comment "//for loop handle stepping"
//pos axlar
int pos1 = 0;
int pos2 = 0;
int pos3 = 0;
int pos4 = 0;
int pos5 = 0;
//stores most amount of steps in a move
int mostStep;
//stores which axle, not in use ccurrently
int longestAxle;
//delay between step pin high and low
const int delayStep = 1;
//stepper drivare
const int stepPin1 = 22;
const int dirPin1 = 23;
const int enPin1 = 24;
const int stepPin2 = 25;
const int dirPin2 = 26;
const int enPin2 = 27;
const int stepPin3 = 28;
const int dirPin3 = 29;
const int enPin3 = 30;
const int stepPin4 = 31;
const int dirPin4 = 32;
const int enPin4 = 33;
const int stepPin5 = 34;
const int dirPin5 = 35;
const int enPin5 = 36;
pinMode(stepPin1, OUTPUT);
pinMode(dirPin1, OUTPUT);
pinMode(enPin1, OUTPUT);
pinMode(stepPin2, OUTPUT);
pinMode(dirPin2, OUTPUT);
pinMode(enPin2, OUTPUT);
pinMode(stepPin3, OUTPUT);
pinMode(dirPin3, OUTPUT);
pinMode(enPin3, OUTPUT);
pinMode(stepPin4, OUTPUT);
pinMode(dirPin4, OUTPUT);
pinMode(enPin4, OUTPUT);
pinMode(stepPin5, OUTPUT);
pinMode(dirPin5, OUTPUT);
pinMode(enPin5, OUTPUT);
//enable drivers
digitalWrite(enPin1, LOW);
digitalWrite(enPin2, LOW);
digitalWrite(enPin3, HIGH);
digitalWrite(enPin4, HIGH);
digitalWrite(enPin5, HIGH);
Serial.println("starta");
//move command (delay between step cycles, join1, joint2, joint3, joint4, joint5)
movJ(1, 500, 300, 50, 30, 30);
delay(10000);
//moves axles
void movJ(int sped, int newPos1, int newPos2, int newPos3, int newPos4, int newPos5){
//calculates most amount of step on an axle in the move and also which axle, stores in global variable
longest(newPos1, newPos2, newPos3, newPos4, newPos5);
//tar fram axeln som är långsammast och tid spara till slowestAxle, slowesTime
//slowest(newPos1, newPos2, newPos3, newPos4, newPos5);
//determines direction off move and sets driver accordingly
if(newPos1-pos1 > 0){
//step positiv
digitalWrite(dirPin1, HIGH);
}else{
//step negativ
digitalWrite(dirPin1, LOW);
if(newPos2-pos2 > 0){
//step positiv
digitalWrite(dirPin2, HIGH);
}else{
//step negativ
digitalWrite(dirPin2, LOW);
if(newPos3-pos3 > 0){
//step positiv
digitalWrite(dirPin3, HIGH);
}else{
//step negativ
digitalWrite(dirPin3, LOW);
if(newPos4-pos4 > 0){
//step positiv
digitalWrite(dirPin4, HIGH);
}else{
//step negativ
digitalWrite(dirPin4, LOW);
if(newPos5-pos5 > 0){
//step positiv
digitalWrite(dirPin5, HIGH);
}else{
//step negativ
digitalWrite(dirPin5, LOW);
//stores how many steps we have taken from last position
int currPos1 = 0;
int currPos2 = 0;
int currPos3 = 0;
int currPos4 = 0;
int currPos5 = 0;
for(int i = 1; i <= mostStep ; i++){
//time between step cycles
delayMicroseconds(sped);
//testprint
Serial.println(map(i, 0, mostStep, 0, abs(pos1-newPos1)));
if(map(i, 0, mostStep, 0, abs(pos1-newPos1)) > currPos1){
//step axle 1
digitalWrite(stepPin1, HIGH);
delayMicroseconds(delayStep);
digitalWrite(stepPin1, LOW);
currPos1++;
}if(map(i, 0, mostStep, 0, abs(pos2-newPos2)) > currPos2){
//step axle 2
digitalWrite(stepPin2, HIGH);
digitalWrite(stepPin2, LOW);
currPos2++;
}if(i*abs(pos3-newPos3)/mostStep > currPos3){
//step axle 3
digitalWrite(stepPin3, HIGH);
digitalWrite(stepPin3, LOW);
currPos3++;
}if(i*abs(pos4-newPos4)/mostStep > currPos4){
//step axle 4
digitalWrite(stepPin4, HIGH);
digitalWrite(stepPin4, LOW);
currPos4++;
}if(i*abs(pos5-newPos5)/mostStep > currPos5){
//step axle 5
digitalWrite(stepPin5, HIGH);
digitalWrite(stepPin5, LOW);
currPos5++;
//puts in the new position in pos variabale
pos1 = pos1+currPos1;
pos2 = pos2+currPos2;
pos3 = pos3+currPos3;
pos4 = pos4+currPos4;
pos5 = pos5+currPos5;
Serial.println(pos1);
Serial.println(pos2);
Serial.println(pos3);
Serial.println(pos4);
Serial.println(pos5);
//tar fram flest antal steg baserat på nuvarande pos
void longest(int newPos1, int newPos2, int newPos3, int newPos4, int newPos5){
mostStep = abs(newPos1-pos1);
longestAxle = 1;
if(abs(newPos2-pos2) > mostStep){
mostStep = abs(newPos2-pos2);
longestAxle = 2;
}if(abs(newPos3-pos3) > mostStep){
mostStep = abs(newPos3-pos3);
longestAxle = 3;
}if(abs(newPos4-pos4) > mostStep){
mostStep = abs(newPos4-pos4);
longestAxle = 4;
}if(abs(newPos5-pos5) > mostStep){
mostStep = abs(newPos5-pos5);
longestAxle = 5;
//tar fram långsammast axel baserat på hastigheten
/*void slowest(int newPos1, int newPos2, int newPos3, int newPos4, int newPos5){
slowestTime = abs(newPos1-pos1)/speed1;
slowestAxle = 1;
if(abs(newPos2-pos2)/speed2 > slowesTime){
slowestTime = abs(newPos2-pos2)/speed2
slowestAxle = 2;
}if(abs(newPos3-pos3)/speed3 > slowesTime){
slowestTime = abs(newPos3-pos3)/speed3
slowestAxle = 3;
}if(abs(newPos4-pos4)/speed4 > slowesTime){
slowestTime = abs(newPos4-pos4)/speed4
slowestAxle = 4;
}if(abs(newPos5-pos5)/speed5 > slowesTime){
slowestTime = abs(newPos5-pos5)/speed5
slowestAxle = 5;
