I have been using the SdFat library to write data to microSD cards but have encountered an issue with slow write speeds on RP2040 boards. I have tried using multiple SD cards (Fat32 and exFAT formatted), an Arduino Nano Connect RP2040 and Sparkfun Things Plus RP2040 board and I can only ever achieve write speeds of around 140kB/S dumping binary data into a file. I also tried a 32GB card (which had a write speed of 140kB/sec with the RP2040 boards) with an Arduino Uno and managed to get write speeds of around 700kB/sec The SdFat library claims to be able to reach speeds of 3000 kB/sec.
It does not make much sense to me that an old Arduino Uno can write to an SD card faster than an RP2040 board? Does anyone have an ideas how I could speed up write speeds?
The code I used to test is adapted from the SdFat library - see below. I have also tried writing blocks sequentially but that did not speed things up.
Hardware wise, the Sparkfun Things Plus has a built in SD card slot and I used this breakout board for the Arduino Nano Connect RP2040 and Arduino Uno.
Any help much appreciated.
* This program is a simple binary write/read benchmark.
#include "SdFat.h"
#include "sdios.h"
#include "FreeStack.h"
// SD_FAT_TYPE = 0 for SdFat/File as defined in SdFatConfig.h,
// 1 for FAT16/FAT32, 2 for exFAT, 3 for FAT16/FAT32 and exFAT.
#define SD_FAT_TYPE 0
Change the value of SD_CS_PIN if you are using SPI and
your hardware does not use the default value, SS.
Common values are:
Arduino Ethernet shield: pin 4
Sparkfun SD shield: pin 8
Adafruit SD shields and modules: pin 10
// SDCARD_SS_PIN is defined for the built-in SD on some boards.
#ifndef SDCARD_SS_PIN
const uint8_t SD_CS_PIN = 9u; //9u for sparkfun things plus
#else // SDCARD_SS_PIN
// Assume built-in SD is used.
const uint8_t SD_CS_PIN = SDCARD_SS_PIN;
#endif // SDCARD_SS_PIN
// Try max SPI clock for an SD. Reduce SPI_CLOCK if errors occur.
#define SPI_CLOCK SD_SCK_MHZ(25)
// Try to select the best SD card configuration.
// #if HAS_SDIO_CLASS
// #define SD_CONFIG SdioConfig(FIFO_SDIO)
// #elif ENABLE_DEDICATED_SPI
#define SD_CONFIG SdSpiConfig(SD_CS_PIN, DEDICATED_SPI, SPI_CLOCK)
// #else // HAS_SDIO_CLASS
// #define SD_CONFIG SdSpiConfig(SD_CS_PIN, SHARED_SPI, SPI_CLOCK)
// #endif // HAS_SDIO_CLASS
// Set PRE_ALLOCATE true to pre-allocate file clusters.
const bool PRE_ALLOCATE = true;
// Set SKIP_FIRST_LATENCY true if the first read/write to the SD can
// be avoid by writing a file header or reading the first record.
const bool SKIP_FIRST_LATENCY = true;
// Size of read/write.
const size_t BUF_SIZE = 512;
// File size in MB where MB = 1,000,000 bytes.
const uint32_t FILE_SIZE_MB = 1;
// Write pass count.
const uint8_t WRITE_COUNT = 2;
// Read pass count.
const uint8_t READ_COUNT = 2;
// End of configuration constants.
// File size in bytes.
const uint32_t FILE_SIZE = 1000000UL*FILE_SIZE_MB;
// Insure 4-byte alignment.
uint32_t buf32[(BUF_SIZE + 3)/4];
uint8_t* buf = (uint8_t*)buf32;
#if SD_FAT_TYPE == 0
SdFat sd;
File file;
#elif SD_FAT_TYPE == 1
SdFat32 sd;
File32 file;
#elif SD_FAT_TYPE == 2
SdExFat sd;
ExFile file;
#elif SD_FAT_TYPE == 3
SdFs sd;
FsFile file;
#else // SD_FAT_TYPE
#error Invalid SD_FAT_TYPE
#endif // SD_FAT_TYPE
// Serial output stream
ArduinoOutStream cout(Serial);
// Store error strings in flash to save RAM.
#define error(s) sd.errorHalt(&Serial, F(s))
void cidDmp() {
cid_t cid;
if (!sd.card()->readCID(&cid)) {
error("readCID failed");
cout << F("\nManufacturer ID: ");
cout << hex << int(cid.mid) << dec << endl;
cout << F("OEM ID: ") << cid.oid[0] << cid.oid[1] << endl;
cout << F("Product: ");
for (uint8_t i = 0; i < 5; i++) {
cout << cid.pnm[i];
cout << F("\nVersion: ");
cout << int(cid.prv_n) << '.' << int(cid.prv_m) << endl;
cout << F("Serial number: ") << hex << cid.psn << dec << endl;
cout << F("Manufacturing date: ");
cout << int(cid.mdt_month) << '/';
cout << (2000 + cid.mdt_year_low + 10 * cid.mdt_year_high) << endl;
cout << endl;
void clearSerialInput() {
uint32_t m = micros();
do {
if (Serial.read() >= 0) {
m = micros();
} while (micros() - m < 10000);
//pinMode(SD_CS_PIN, OUTPUT);
// Wait for USB Serial
while (!Serial) {
yield();
cout << F("\nUse a freshly formatted SD for best performance.\n");
Serial.println(SD_CS_PIN);
if (!ENABLE_DEDICATED_SPI) {
cout << F(
"\nSet ENABLE_DEDICATED_SPI nonzero in\n"
"SdFatConfig.h for best SPI performance.\n");
// use uppercase in hex and use 0X base prefix
cout << uppercase << showbase << endl;
float s;
uint32_t t;
uint32_t maxLatency;
uint32_t minLatency;
uint32_t totalLatency;
bool skipLatency;
// Discard any input.
clearSerialInput();
// // F() stores strings in flash to save RAM
// cout << F("Type any character to start\n");
// while (!Serial.available()) {
// yield();
#if HAS_UNUSED_STACK
cout << F("FreeStack: ") << FreeStack() << endl;
#endif // HAS_UNUSED_STACK
if (!sd.begin(SD_CONFIG)) {
sd.initErrorHalt(&Serial);
if (sd.fatType() == FAT_TYPE_EXFAT) {
cout << F("Type is exFAT") << endl;
cout << F("Type is FAT") << int(sd.fatType()) << endl;
cout << F("Card size: ") << sd.card()->sectorCount()*512E-9;
cout << F(" GB (GB = 1E9 bytes)") << endl;
cidDmp();
// open or create file - truncate existing file.
if (!file.open("bench.dat", O_RDWR | O_CREAT | O_TRUNC)) {
error("open failed");
// fill buf with known data
if (BUF_SIZE > 1) {
for (size_t i = 0; i < (BUF_SIZE - 2); i++) {
buf[i] = 'A' + (i % 26);
buf[BUF_SIZE-2] = '\r';
buf[BUF_SIZE-1] = '\n';
cout << F("FILE_SIZE_MB = ") << FILE_SIZE_MB << endl;
cout << F("BUF_SIZE = ") << BUF_SIZE << F(" bytes\n");
cout << F("Starting write test, please wait.") << endl << endl;
// do write test
uint32_t n = FILE_SIZE/BUF_SIZE;
cout <<F("write speed and latency") << endl;
cout << F("speed,max,min,avg") << endl;
cout << F("KB/Sec,usec,usec,usec") << endl;
for (uint8_t nTest = 0; nTest < WRITE_COUNT; nTest++) {
file.truncate(0);
if (PRE_ALLOCATE) {
if (!file.preAllocate(FILE_SIZE)) {
error("preAllocate failed");
maxLatency = 0;
minLatency = 9999999;
totalLatency = 0;
skipLatency = SKIP_FIRST_LATENCY;
t = millis();
for (uint32_t i = 0; i < n; i++) {
if (file.write(buf, BUF_SIZE) != BUF_SIZE) {
error("write failed");
m = micros() - m;
totalLatency += m;
if (skipLatency) {
// Wait until first write to SD, not just a copy to the cache.
skipLatency = file.curPosition() < 512;
if (maxLatency < m) {
maxLatency = m;
if (minLatency > m) {
minLatency = m;
file.sync();
t = millis() - t;
s = file.fileSize();
cout << s/t <<',' << maxLatency << ',' << minLatency;
cout << ',' << totalLatency/n << endl;
cout << endl << F("Starting read test, please wait.") << endl;
cout << endl <<F("read speed and latency") << endl;
file.close();
