OK!
So i tried a new way.
Now i just let the interrupt increase revcount, when it is above a certain value (20), the arduino prints
revcount and the elapsed time since the last print.
I let the processing program handle all the calculations, hz, rpm, power and so on.
Since i dont have my dyno at home, i wrote a code that sends fake revcount and time readings with a delay of 1ms to my laptop.
The processing software can read and handle all the data from the fake readings at this high speed.
So this way i have basicly minimized the work for the arduino and let the laptop do it instead.
3ghz is faster than 16mhz right?
Ill try this tomorrow.
Fake serial print code
VeraDyno
Fredrik Johansson 2013
Purpose:
Send rpmcounts and millis to processing
Serial.begin(115200); //Faster baud?
Serial.print("20");
Serial.print(" ");
Serial.println("550");
delay(1);
Serial.print("20");
Serial.print(" ");
Serial.println("500");
delay(1);
Serial.print("20");
Serial.print(" ");
Serial.println("450");
delay(1);
Serial.print("20");
Serial.print(" ");
Serial.println("400");
delay(1);
Serial.print("20");
Serial.print(" ");
Serial.println("350");
delay(1);
Serial.print("20");
Serial.print(" ");
Serial.println("300");
delay(1);
Serial.print("20");
Serial.print(" ");
Serial.println("250");
delay(1);
Serial.print("20");
Serial.print(" ");
Serial.println("200");
delay(1);
Serial.print("20");
Serial.print(" ");
Serial.println("150");
delay(1);
Serial.print("20");
Serial.print(" ");
Serial.println("100");
delay(1);
delay(10000);
The real code for the arduino:
// Variables
unsigned long lastmillis=0;
unsigned long deltamillis=0;
volatile byte revcount = 0;
attachInterrupt(0, revInterrupt, RISING);
if (revcount>20) {
deltamillis = millis() - lastmillis;
lastmillis = millis();
Serial.print(revcount); //Print current hz
Serial.print(" "); //Print space
Serial.println(deltamillis); //Print elapsed time
revcount=0;
void revInterrupt() {
revcount++;
The processing code:
Veradyno
import processing.serial.*;
Serial port;
PrintWriter output;
PImage img;
// Variables
//Data
String[] splitdata;
long hz=0;
long hzold=0;
float watt;
float wattold=0;
float rpm;
float rpmold;
int revcount = 0;
int revcountold=0;
float rads2;
float rads1;
long maxhzrulle=100;
int dtime=1; // Time between readings
int timeold=1; // To keep time of readingss
String fileExtension = ".txt";
// Colors
long bgcolor=40;
long bgcolor2=60;
long txtcolor=240;
// Time and date
long year = year();
long month = month();
long day = day();
long hour = hour();
long minute = minute();
long second = second();
float inertia = 0.054405996665378;
// GUI---------------------------
background(bgcolor); //Background color
size(100, 210); // Picture size
img = loadImage("logo.JPG"); // Image
image(img, 270, 0);
size(800, 600); //Screen size
frame.setTitle("Vera Dyno"); // Title of window
textSize(32);
fill(txtcolor);
text("Vera dyno", 10, 50); //Header
fill(bgcolor2);
strokeWeight(0);
rect(50, 100, 610, 450); // Plot window
fill(255);
fill(txtcolor);
textSize(20);
text("Rpm:", 670, 130); // Measurements
text("Millis:", 670, 170); // Measurements
textSize(18);
text("0", 17, 555);
text("Watt", 4, 335);
text("1000", 3, 120);
text("0", 45, 580);
text("Rpm", 320, 580);
text(maxhzrulle, 600, 580);
// Serial communication
port = new Serial(this, "COM6", 115200); //port baud 9600
port.bufferUntil('\n'); // buffer until prlonged line prlongln
//Logging file specification
output = createWriter(year + "-" + month + "-" + day + " " + hour + "_" + minute + "_" + second + ".txt");
output.print("HZ "); // Headers for logging file
output.println("WATT");
void draw() {
void serialEvent (Serial port) {
splitdata = splitTokens(port.readStringUntil('\n'));
revcount= int(splitdata[0]);
dtime = int(splitdata[1]);
revcount=revcount*1000;
hz=(revcount/dtime);
if (hz>hzold) {
rads2 = (hz)*2*3.14;
rads1 = (hzold)*2*3.14;
float E2=0.5*inertia*(rads2*rads2);
float E1=0.5*inertia*(rads1*rads1);
watt=((E2-E1)/dtime)*1000;
rads1=rads2;
// // plotting
rpm=hz*60;
rpm=map(rpm, 0, 5000, 0, 250);
float watt2=map(watt, 0, 50000, 0, 100);
strokeWeight(3);
stroke(0);
line(rpmold+50, 550-wattold, rpm+50, 550-watt2);
rpmold=rpm;
wattold=watt2;
output.print(hz);
output.print(" ");
output.println(watt); //Prlonging to file
output.flush(); // Writes the remaining data to the file
hzold=hz;
