Hello, I'm looking to design my own touch screen controller for my robot. The touch screen i'm using, uses all my pins on the Arduino UNO Rev 3, including the Tx and Rx. My robot is currently being controlled from my laptop via Bluetooth, and I was tring to design my own controller, using various Arduino components.Now because the touch screen uses every pin on my UNO, I looked at the Mega because it has more Tx and RX pins to use, but it was WAY too long and rather bulky. So, I was wondering if a smaller, more compact version of the Mega was, is or could be made. Something more like the Arduino Mini, same amount of pins just more compact. This way I can integrate more parts like an accelerometer and even a bluetooth module to communicate to the one on my robot.
Check the docs, most of these chips allow the highspeed serial (for SPI/I2C/etc) to be used as hardware serial.
There are people here building custom ATMega1284 setups. It has 40 pins and 2 USARTs.
If you can find space the you can connect 1 or more shift registers to the UNO SPI pins and add pins that way. There are even bi-directional shift registers.
Hmmm, I need at least 2 USARTs, one for the touch screen and the other for the bluetooth module.
Could I maybe design my own custom board, like the Teensy?
You can use SoftSerial on just about any two pins to add serial channels. It's part of the IDE, make sure you use the version that comes with your IDE.
A touchscreen controller chip would probably reduce the pins needed for TS to just 2.
I'm here, just slow reading tonight.
Are you handy with a soldering iron? This board could be all you need:
$4.50 for a bareboard mailed to your US address, you scrounge for (or purchase) parts & assemble.
Use an offboard FTDI Basic or equivalent to download sketches, or a Mikroelectronica FTDI module can be installed on the right.
I supposed I can offer assembled units too, no one's asked for one yet.
Does it say anywhere what AVR that Illuminato actually uses?
I wouldn't mind seeing SMT chip breakouts built onto 40 pin sockets, or to fit into them. I've seen boards that I think the like would run on. A 2560 w/external 32+K RAM in that format would rock and roll too.
Goal is to combine gprs, temp, humidity, motion sensing, door switch and camera in one package and post results to website. Anywho, been lurking for a couple months and figured I share some info rather than ask a question on my first post. The amount of info on these boards is fantastic.
