Smallest Real time clock?
Hello, I'm trying to find a good and accurate Real time clock chip that is small enough I can fit in a watch Project I'm building. Does anyone know of any that works with Arduino? I found a small package one of the DS3231 But at almost $9 USD. That is a little to much. Can someone please help me in figuring out What RTC would be good please?
Joseph
Try the:
MCP79412RTC RTC
To change from using a DS1307 RTC to an MCP7941x RTC, it is only necessary to use #include <MCP79412RTC.h> instead of #include <DS1307RTC.h>.
I was able to snag 10 of the SOIC-8 DS3231 (counterfeit) before the chip shortage for $1 a pop. Now AliExpress charges $4 for each...
Hello LarryD The 1307 I will never use in a watch project Because of losing time. A lot of time. Now the MCP7941x I will take a look at thank you very much.
Joseph
I can get the 8pin Version however I'm seeing it at $8 or $9 usd dollars. or in china itis cheaper. But sense I'm on a crunch I guess you can say I might need to bite my tongue and get one.
Joseph
See:
I did mange to find PCF8563 I few seconds ago and saw it holdsgreat time for under $2 a chip. I'm going to grab a few it looks like. Thank you all for the help. i'm going to look at MCP7941x also.
Joseph
$1.39
:wink:
Yes, I'm seeing it at $1.03 at the moment.
Joseph
If you use an AVR chip like the ATmega328, it can act as an RTC. Timer2 can use a 32768 Hz crystal as the clock source, while the processor sleeps.
The processor runs on the internal RC clock when it is awake.
Simple example code:
// low power BCD RTC using bare bones ATMega328p, no regulator, 3-5V
// update 5/2021
// ASCII RTC buffer, maintains C-string HH:MM:SS
// This code creates an RTC formed by Timer2. Requires 32768 Hz xtal + 2x30 pF caps on OSC pins
// Low power operation borrowed heavily from https://www.gammon.com.au/power
// SET FUSES: 8 MHz internal RC clock
// S. James Remington 3/2013
//tested on 8MHz internal clock mini-duino http://www.crossroadsfencing.com/BobuinoRev17/
#include <avr/sleep.h>
#include <util/delay.h>
// Global variables for RTC
//                                 0   1       3   4       6   7
volatile unsigned char RTC_buf[]={'0','0',':','0','0',':','0','0',0}; //hh:mm:ss, with zero terminator
volatile unsigned int dayno = 0; //days since startup
#define BUF_LEN 20
char buf[BUF_LEN];  //print message buffer
  Serial.println("Simple RTC");
  //PRR Power Reduction Register (set PRADC after ADCSRA=0)
  //Bit 7 - PRTWI: Power Reduction TWI
  //Bit 6 - PRTIM2: Power Reduction Timer/Counter2
  //Bit 5 - PRTIM0: Power Reduction Timer/Counter0
  //Bit 3 - PRTIM1: Power Reduction Timer/Counter1
  //Bit 2 - PRSPI: Power Reduction Serial Peripheral Interface
  //Bit 1 - PRUSART0: Power Reduction USART0
  //Bit 0 - PRADC: Power Reduction ADC
  ADCSRA = 0; //disable ADC
  // turn off  unneeded modules.
  PRR |= (1 << PRTWI) | (1 << PRTIM1) | (1 << PRSPI) | (1 << PRADC); // | (1 << PRUSART0) ;
  // reprogram timer 2 for this application
  timer2_init();
  static char t = 0;  //must be static or global
    // wake up on Timer2 overflow (1/sec)
    // output day, time and cpu voltage on serial monitor every ... (10 seconds now)
    if (t != RTC_buf[6]) { //have 10 seconds passed?
      t = RTC_buf[6];
/* turn on ADC if needed
      PRR &= ~((1 << PRADC) | (1 << PRUSART0)); //turn on ADC and USART
      ADCSRA = (1 << ADEN); //set up ADC properly
      ADCSRA |= (1 << ADPS0) | (1 << ADPS1) | (1 << ADPS2); // ADC Prescaler=128
      //    print day, time
      snprintf(buf, BUF_LEN, "%s/%u", RTC_buf, dayno);
      Serial.println(buf);
      Serial.flush(); //finish printing before going to sleep
      // back to sleep with modules off
/* adc back off, if on
      ADCSRA = 0; //ADC off
      PRR |= (1 << PRADC) | (1 << PRUSART0);  //turn off ADC and USART
    } //end if (t)
// go back to sleep
    set_sleep_mode(SLEEP_MODE_PWR_SAVE);
    sleep_enable();
    cli(); //time critical steps follow
    MCUCR = (1 << BODS) | (1 << BODSE); // turn on brown-out enable select
    MCUCR = (1 << BODS);         //Brown out off. This must be done within 4 clock cycles of above
    sei();
    sleep_cpu();
//  Timer2 Interrupt Service
//  32 kKz / 256 = 1 Hz with Timer2 prescaler 128
//  provides global tick timer and BCD ASCII Real Time Clock
//  no check for illegal values of RTC_buffer upon startup!
ISR (TIMER2_OVF_vect) {
// RTC function
    RTC_buf[7]++;    // increment second
     if (RTC_buf[7] > '9')
      RTC_buf[7]='0'; // increment ten seconds
      RTC_buf[6]++;
      if ( RTC_buf[6] > '5')
        RTC_buf[6]='0';
        RTC_buf[4]++;     // increment minutes
          if (RTC_buf[4] > '9')
          RTC_buf[4]='0';
          RTC_buf[3]++;   // increment ten minutes
          if (RTC_buf[3] > '5')
          RTC_buf[3]='0';
          RTC_buf[1]++;     // increment hours
          char b = RTC_buf[0]; // tens of hours, handle rollover at 19 or 23
            if ( ((b < '2') && (RTC_buf[1] > '9')) || ((b=='2') && (RTC_buf[1] > '3')) )
            RTC_buf[1]='0';
            RTC_buf[0]++;   // increment ten hours and day number, if midnight rollover
            if (RTC_buf[0] > '2') {RTC_buf[0]='0'; dayno++;}
// initialize Timer2 as asynchronous 32768 Hz timing source
void timer2_init(void) {
  TCCR2A = 0;
  TCCR2B = 0;  //stop Timer 2
  TIMSK2 = 0; // disable Timer 2 interrupts
  ASSR = (1 << AS2); // select asynchronous operation of Timer2
  TCNT2 = 0; // clear Timer 2 counter
  TCCR2B = (1 << CS22) | (1 << CS20); // select prescaler 128 => 1 sec between each overflow
  while (ASSR & ((1 << TCN2UB) | (1 << TCR2BUB))); // wait for TCN2UB and TCR2BUB to be cleared
  TIFR2 = (1 << TOV2); // clear interrupt-flag
  TIMSK2 = (1 << TOIE2); // enable Timer2 overflow interrupt
Hello jremington, I'm looking at using my samD21 processors I have 3 of them. I was thinking of Using That as The clock because of the 32Khz Crystal. However I don't know running a clock and doing all if functions From just one Chip would be good. Maybe I'm wrong but That is why I'm looking into A external clock chip.
P.s.s The avr as clock looks really Interesting. Thank you very much.
Joseph.
I would be very, very surprised if the SamD21 processors are not capable of doing the same thing, that is, use a timer connected to an external 32 kHz xtal as an RTC, but they are MUCH harder to program.
EDIT: they do, and and it is trivial to make an RTC: SAMD21 Mini/Dev Breakout Hookup Guide - SparkFun Learn
In the example I posted, the ATmega328 CPU does basically nothing, so you have the full power of a standard Arduino Uno at your service, albeit at 8 MHz.
The D21 is ran in the Arduino zero board can run as a clock. I have already done it There is a Arduino zero RTC clock code. That I have ran before. But I was always worried running a LCD screen and other functions While the clock was running and might Skip a minute or two while the other function are running.
Joseph
No chance of that, with either MCU. The timer runs asynchronously and independently.
Interesting. I will have a look at it more. But the Avr clock is surprising me for another project I been looking into.
Joseph
Is there a schmatic or something I can look into seeing this more to wire it up?
Joseph
For the AVR option, just replace the usual 16 MHz crystal or resonator with a 32768 Hz watch crystal, with 2x30 pF caps from the crystal leads to ground.
Before you do that, set the fuses for 8MHz internal RC and either use an ISP programmer, or replace the bootloader with an 8 MHz bootloader.
Thank you, I will try it out because I do have a 10 pack of 32khz crystals from Mouser a few months back. I think this be a cool project after the holidays.
Joseph
scroll the page down
The SAMD21 has an RTC peripheral that can be clocked from an external 32768 Hz crystal (or from the internal 32 K). Some board even have this crystal connected so it's just programming at that point
