Smart Alarm Clock
I am trying to make this: S.M.A.R.T. Alarm Clock - Make: and I can't get the code to display the proper things on the screen.
I am using an Arduino Yún with the TFT Touch Shield from Seed Studio.
The code is attached.
When I compile it, I get these warning messages:
/Users/eli2/Downloads/SmartAlarmClock-master/SmartAlarmClock/SmartAlarmClock.ino: In function 'void setup()':
/Users/eli2/Downloads/SmartAlarmClock-master/SmartAlarmClock/SmartAlarmClock.ino:95:60: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
   Tft.drawString("LOADING...", MAX_X-10, 10, 3, CLOCK_COLOR);
/Users/eli2/Downloads/SmartAlarmClock-master/SmartAlarmClock/SmartAlarmClock.ino: In function 'void loop()':
/Users/eli2/Downloads/SmartAlarmClock-master/SmartAlarmClock/SmartAlarmClock.ino:165:65: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
     Tft.drawString("REFRSH", REFRESH_X+30, REFRESH_Y+5, 2, BLACK);
/Users/eli2/Downloads/SmartAlarmClock-master/SmartAlarmClock/SmartAlarmClock.ino: In function 'void draw_display(int, int)':
/Users/eli2/Downloads/SmartAlarmClock-master/SmartAlarmClock/SmartAlarmClock.ino:354:59: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
     Tft.drawString("ALARM:", MAX_X-50, 215, 2, CLOCK_COLOR);
/Users/eli2/Downloads/SmartAlarmClock-master/SmartAlarmClock/SmartAlarmClock.ino:357:69: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
     Tft.drawString("CANCEL", CANCEL_X+30, CANCEL_Y+5, 2, CLOCK_COLOR);
/Users/eli2/Downloads/SmartAlarmClock-master/SmartAlarmClock/SmartAlarmClock.ino:361:69: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
   Tft.drawString("REFRSH", REFRESH_X+30, REFRESH_Y+5, 2, CLOCK_COLOR);
Sketch uses 20,350 bytes (70%) of program storage space. Maximum is 28,672 bytes.
Global variables use 877 bytes (34%) of dynamic memory, leaving 1,683 bytes for local variables. Maximum is 2,560 bytes.
And nothing is displayed on the screen. Any help?
SmartAlarmClock.ino (12.4 KB)
Warnings can be ignored. If nothing appears on the screen, one has to wonder why you wrote so damned much code. Surely a single tft.drawString(), in setup() would have illustrated the problem.
Did you bother with any of the examples?
