I probably should be able to figure this out, but I just can't get my head around it.
I'm reading from 4 temperature sensors, using the smoothing code on the arduino site to get ten readings from each sensor, and take an average. At the moment, I'm writing this out 'long-hand' by doing this for each sensor.
Can anyone tell me a way of putting each average reading from each sensor (after smoothing) in to another array to get the average of all these.
So, for example ten readings from each sensor, take an average, put each average from each sensor and take an average from this.
This is the smoothing code:
#define NUMREADINGS 10
int readings[NUMREADINGS]; // the readings from the analog input
int index = 0; // the index of the current reading
int total = 0; // the running total
int average = 0; // the average
int inputPin = 0;
Serial.begin(9600); // initialize serial communication with computer
for (int i = 0; i < NUMREADINGS; i++)
readings[i] = 0; // initialize all the readings to 0
total -= readings[index]; // subtract the last reading
readings[index] = analogRead(inputPin); // read from the sensor
total += readings[index]; // add the reading to the total
index = (index + 1); // advance to the next index
if (index >= NUMREADINGS) // if we're at the end of the array...
index = 0; // ...wrap around to the beginning
average = total / NUMREADINGS; // calculate the average
Serial.println(average); // send it to the computer (as ASCII digits)
I think this should work as you described. I've always found nested arrays the easiest way to handle data sets like this. I don't have any hardware to test this. Obviously your readings will be bogus until the data arrays are filled with good data.
Another thing to be noted as well. This will print out the average of the analogRead function. This will need to be scaled with your hardware slope, via a multiplier of totalAverage.
#define NUMSENSORS 4
int readings[NUMSENSORS][NUMREADINGS]; // the readings from the analog input
float total = 0; // the running total
float average[NUMSENSORS]; // the average
float totalAverage;
int i,j;
int inputPin[NUMSENSORS] = {0,1,2,3};
for(i=0;i<NUMSENSORS;i++)
for(j=0;j<NUMREADINGS; j++)
readings[i][j]= 0; // Clear the data
for(i=0; i<NUMSENSORS; i++) // This handles the data for each sensor
for(j=0; j<NUMREADINGS - 1; j++)
readings[i][j+1] = readings[i][j]; // Shift to make room for the new reading
readings[i][0] = analogRead(inputPin[i]); // get the latest value
for(i=0; i<NUMSENSORS; i++) // Average each sensor
total = 0; // Reset the total for each sensor
for(j=0; j<NUMREADINGS; j++)
total += readings[i][j];
average[i] = total / NUMREADINGS;
total = 0; // Reset total again for use with totalAverage
for(i=0; i<NUMSENSORS; i++) // Average all sensors together
total += average[i];
totalAverage = total / NUMSENSORS;
Serial.println(totalAverage); // send it to the computer (as ASCII digits)
So, it's nested arrays, rather than two dimensional arrays? This is what I was trying to find, I think.
Is the average of the individual sensors of any interest? If not, you can just take the average of all readings.
Also, to avoid bogus results until the array is filled with actuals, you can fill it with the result of one initial reading. Then you'll get sensible data from the first reading.
Something like this (NB! Untested code.):
#define SENSORS 4
#define READINGS_PER_SENSOR 10
#define READINGS READINGS_PER_SENSOR * SENSORS
#define SENSOR_1 0
#define SENSOR_2 1
#define SENSOR_3 2
#define SENSOR_4 3
int readings[READINGS];
void setup(void)
// Fill the array with an initial actual reading
for (int i = 0; i < READINGS; i++)
readings[i] = analogRead(SENSOR_1);
void loop(void)
// Read from each sensor
sensor_read(SENSOR_1);
sensor_read(SENSOR_2);
sensor_read(SENSOR_3);
sensor_read(SENSOR_4);
// Print average to serial port
Serial.println(average_reading());
// Do other stuff if you need to
// Insert a reading
void sensor_read(int sensor)
// Shift out the last reading
for (int i = 1; i < READINGS; i++)
readings[i] = readings[i-1];
// Insert the new reading
readings[0] = analogRead(sensor);
// Find average of all readings
float average_reading(void)
long sum = 0;
sum += readings[i];
return sum/READINGS;
Unless I'm mistaken, nested and multidimensional arrays are the same thing.
Also, I think it is worth noting the amount of time it takes to fill your arrays with 10 readings is very small. I ran my serial monitor and I couldn't even read the first 10 outputs. If you were to run a delay this might be a concern.
Also skumlerud, your initial setup will fill the array with readings from sensor 1 only. So i would argue that that data is bogus as well becuause you are not getting a true average of all 4 sensors until you have called your sensor read 10 times for all 4 sensors.
I've always thought of a n dimensional array as a datastructure with a variable at all indexes.
And nested arrays I've thought of as a more dynamic:
Here at index 1 , 2 the value of the 'pointed' [dereferenced contents of the pointer] is 1
But at 1,3 the poited data is yet another pointer (to yet another array, this is in my point of view a 'nested' array)
Yes, exactly the same! But in BASIC, the syntax uses a commas to separate the index numbers, whereas in C you write the entire index, including the brackets, twice (square brackets in C of course). I was just trying to point out the difference in syntax.
