This is not a finished project but will be part of another project that I cannot post but I figure someone may find it useful if you use deal with equipment using this type of signal.
This is an AVR/Arduino equivalent of a PIC based project I made over a decade ago that I felt needed dragging into the (slightly more) modern age. It was originally written in assembler due to the slow clock speed used on the PIC (4.43361875MHz) but has converted to C++ a lot easier than I expected.
I have tested it with PAL signals but it should also work with NTSC if the timings are altered.
// SMPTE Timecode Reader
// Uses INT0 (Pin 2)
PAL = 25FPS = 40ms per frame
40ms / 80bits = 500us per bit
250us per half bit
125us per quarter bit
0 bit max = 625us
1 bit max = 375us (also 0 bit min)
1 bit min = 125us
NTSC = 30FPS (29.97) = 33.333ms per frame
40ms / 80bits = 417us per bit
208us per half bit
104us per quarter bit
0 bit max = 521us
1 bit max = 312us (also 0 bit min)
1 bit min = 104us
#define uMax0 625 // Any time greater than this is to big
#define uMax1 375 // Midpoint timing between a 1 and 0 bit length
#define uMin1 125 // Any time less than this is to short
const word sync = 0xBFFC; // Sync word to expect when running tape forward
enum flagBits {
tcValid, // TC copied to xtc is valid (Used by main loop to determing if a timecode has arrived)
tcFrameError, // ISR edge out of timing bounds (only gets reset after next valid TC read)
tcOverrun, // TC was not read from xtc by main loop before next value was ready (so main loop can tell if timecodes have been lost)
tcForceUpdate, // Valid TC will always be copied to buffer even if last value not read (if set by main code then TC will always be copied)
tcHalfOne // ISR is reading a 1 bit so ignore next edge (Internal to ISR)
uint8_t tc[10] = {0}; // ISR Buffer to store incoming bits
volatile uint8_t xtc[8] = {0}; // Buffer to store valid TC data - sync bytes
volatile uint8_t tcFlags = 0; // Various flags used by ISR and main code
uint32_t uSeconds; // ISR store of last edge change time
char timeCode[12]; // For example code another buffer to write decoded timecode
char userBits[12]; // For example code another buffer to write decoded user bits
void setup(){
pinMode(2,INPUT);
attachInterrupt(0, int0ISR, CHANGE);
Serial.println(F("Waiting For TC"));
void loop(){
while(bitRead(tcFlags, tcValid) == 0){}; // Wait for valid timecode
timeCode[0] = (xtc[0] & 0x03) + '0'; // 10's of hours
timeCode[1] = (xtc[1] & 0x0F) + '0'; // hours
timeCode[2] = ':';
timeCode[3] = (xtc[2] & 0x07) + '0'; // 10's of minutes
timeCode[4] = (xtc[3] & 0x0F) + '0'; // minutes
timeCode[5] = ':';
timeCode[6] = (xtc[4] & 0x07) + '0'; // 10's of seconds
timeCode[7] = (xtc[5] & 0x0F) + '0'; // seconds
timeCode[8] = '.';
timeCode[9] = (xtc[6] & 0x03) + '0'; // 10's of frames
timeCode[10] = (xtc[7] & 0x0F) + '0'; // frames
userBits[0] = ((xtc[7] & 0xF0) >> 4) + '0'; // user bits 1
userBits[1] = ((xtc[6] & 0xF0) >> 4) + '0'; // user bits 2
userBits[2] = '-';
userBits[3] = ((xtc[5] & 0xF0) >> 4) + '0'; // user bits 3
userBits[4] = ((xtc[4] & 0xF0) >> 4) + '0'; // user bits 4
userBits[5] = '-';
userBits[6] = ((xtc[3] & 0xF0) >> 4) + '0'; // user bits 5
userBits[7] = ((xtc[2] & 0xF0) >> 4) + '0'; // user bits 6
userBits[8] = '-';
userBits[9] = ((xtc[1] & 0xF0) >> 4) + '0'; // user bits 7
userBits[10] = ((xtc[0] & 0xF0) >> 4) + '0'; // user bits 8
bitClear(tcFlags, tcValid); // Finished with TC so signal to ISR it can overwrite it with next TC
Serial.print(timeCode);
Serial.print("\t");
Serial.println(userBits);
void int0ISR(){
uint32_t edgeTimeDiff = micros() - uSeconds; // Get time difference between this and last edge
uSeconds = micros(); // Store time of this edge
if ((edgeTimeDiff < uMin1) or (edgeTimeDiff > uMax0)) { // Drop out now if edge time not withing bounds
bitSet(tcFlags, tcFrameError);
return;
if (edgeTimeDiff > uMax1) // A zero bit arrived
if (bitRead(tcFlags, tcHalfOne) == 1){ // But we are expecting a 1 edge
bitClear(tcFlags, tcHalfOne);
clearBuffer(tc, sizeof(tc));
return;
// 0 bit
shiftRight(tc, sizeof(tc)); // Rotate buffer right
// Shift replaces top bit with zero so nothing else to do
//bitClear(tc[0], 7); // Reset the 1 bit in the buffer
else // Not zero so must be a 1 bit
{ // 1 bit
if (bitRead(tcFlags, tcHalfOne) == 0){ // First edge of a 1 bit
bitSet(tcFlags, tcHalfOne); // Flag we have the first half
return;
// Second edge of a 1 bit
bitClear(tcFlags, tcHalfOne); // Clear half 1 flag
bitSet(tc[0], 7); // Set the 1 bit in the buffer
// Congratulations, we have managed to read a valid 0 or 1 bit into buffer
if (word(tc[0], tc[1]) == sync){ // Last 2 bytes read = sync?
bitClear(tcFlags, tcFrameError); // Clear framing error
bitClear(tcFlags, tcOverrun); // Clear overrun error
if (bitRead(tcFlags, tcForceUpdate) == 1){
bitClear(tcFlags, tcValid); // Signal last TC read
if (bitRead(tcFlags, tcValid) == 1){ // Last TC not read
bitSet(tcFlags, tcOverrun); // Flag overrun error
return; // Do nothing else
for (uint8_t x = 0; x < sizeof(xtc); x++){ // Copy buffer without sync word
xtc[x] = tc[x + 2];
bitSet(tcFlags, tcValid); // Signal valid TC
void clearBuffer(uint8_t theArray[], uint8_t theArraySize){
for (uint8_t x = 0; x < theArraySize - 1; x++){
theArray[x] = 0;
void shiftRight(uint8_t theArray[], uint8_t theArraySize){
uint8_t x;
for (x = theArraySize; x > 0; x--){
uint8_t xBit = bitRead(theArray[x - 1], 0);
theArray[x] = theArray[x] >> 1;
theArray[x] = theArray[x] | (xBit << 7);
I just found this helpful site that you can download timecode audio from. I might be tempted to check the NTSC timings at some point.
