SMS messages cut off last character. Is this a buffer size matter?
I am testing the BotleticsSIM7000.h library, working with SMS message reception. With a SIM7670NA modem.
Every thing seems to be working, except the received SMS messages are having the last character not display. So sending "Testing" is reading and displaying "Testin. With "g" " cut off. So the the SMS response fails because of this too.
Serial monitor display:
+CMGR: "REC READ","+1727xxxxxxx","","25/06/08,15:22:31-28",145,36,0,0,"+12063130004",145,7
"Testin
Test code is:
/*  This is an example sketch that receives text messages from the user
 *   and sends a response back dto the user depending on what the
 *   message was! You can use this code for all sorts of cool applications
 *   like remote sensors, SMS-activated controls, and many other things!
 *  Author: Timothy Woo (www.botletics.com)
 *  Github: https://github.com/botletics/NB-IoT-Shield
 *  Last Updated: 1/7/2021
 *  License: GNU GPL v3.0
#include "BotleticsSIM7000.h" // https://github.com/botletics/Botletics-SIM7000/tree/main/src
/******* ORIGINAL ADAFRUIT FONA LIBRARY TEXT *******/
  This is an example for our Adafruit FONA Cellular Module
  Designed specifically to work with the Adafruit FONA
  ----> http://www.adafruit.com/products/1946
  ----> http://www.adafruit.com/products/1963
  ----> http://www.adafruit.com/products/2468
  ----> http://www.adafruit.com/products/2542
  These cellular modules use TTL Serial to communicate, 2 pins are
  required to interface
  Adafruit invests time and resources providing this open source code,
  please support Adafruit and open-source hardware by purchasing
  products from Adafruit!
  Written by Limor Fried/Ladyada for Adafruit Industries.
  BSD license, all text above must be included in any redistribution
// #include "Botletics_modem.h" // https://github.com/botletics/SIM7000-LTE-Shield/tree/master/Code
#if defined(ARDUINO_SAMD_ZERO) && defined(SERIAL_PORT_USBVIRTUAL)
  // Required for Serial on Zero based boards
  #define Serial SERIAL_PORT_USBVIRTUAL
#endif
// Define *one* of the following lines:
//#define SIMCOM_2G // SIM800/808/900/908, etc.
//#define SIMCOM_3G // SIM5320
//#define SIMCOM_7000
//#define SIMCOM_7070
//#define SIMCOM_7500
#define SIMCOM_7600
// For botletics SIM7000 shield
#define BOTLETICS_PWRKEY 6
#define RST 7
//#define DTR 8 // Connect with solder jumper
//#define RI 9 // Need to enable via AT commands
#define TX 3 // Microcontroller RX
#define RX 4 // Microcontroller TX
//#define T_ALERT 12 // Connect with solder jumper
// For botletics SIM7500 shield
//#define BOTLETICS_PWRKEY 6
//#define RST 7
////#define DTR 9 // Connect with solder jumper
////#define RI 8 // Need to enable via AT commands
//#define TX 11 // Microcontroller RX
//#define RX 10 // Microcontroller TX
////#define T_ALERT 5 // Connect with solder jumper
// We default to using software serial. If you want to use hardware serial
// (because softserial isnt supported) comment out the following three lines
// and uncomment the HardwareSerial line
#include <SoftwareSerial.h>
SoftwareSerial modemSS = SoftwareSerial(TX, RX);
// Use the following line for ESP8266 instead of the line above (comment out the one above)
//SoftwareSerial modemSS = SoftwareSerial(TX, RX, false, 256); // TX, RX, inverted logic, buffer size
SoftwareSerial *modemSerial = &modemSS;
// Hardware serial is also possible!
//HardwareSerial *modemSerial = &Serial1;
// For ESP32 hardware serial use these lines instead
//#include <HardwareSerial.h>
//HardwareSerial modemSS(1);
// Use this for 2G modules
#ifdef SIMCOM_2G
  Botletics_modem modem = Botletics_modem(RST);
// Use this one for 3G modules
#elif defined(SIMCOM_3G)
  Botletics_modem_3G modem = Botletics_modem_3G(RST);
// Use this one for LTE CAT-M/NB-IoT modules (like SIM7000)
// Notice how we don't include the reset pin because it's reserved for emergencies on the LTE module!
#elif defined(SIMCOM_7000) || defined(SIMCOM_7070) || defined(SIMCOM_7500) || defined(SIMCOM_7600)
Botletics_modem_LTE modem = Botletics_modem_LTE();
#endif
uint8_t readline(char *buff, uint8_t maxbuff, uint16_t timeout = 0);
uint8_t type;
char imei[16] = {0}; // MUST use a 16 character buffer for IMEI!
//  while (!Serial);
  pinMode(RST, OUTPUT);
  digitalWrite(RST, HIGH); // Default state
  // Turn on the module by pulsing PWRKEY low for a little bit
  // This amount of time depends on the specific module that's used
  modem.powerOn(BOTLETICS_PWRKEY); // Power on the module
  Serial.println(F("SMS Response Test"));
  Serial.println(F("Initializing...."));
  // SIM7000 takes about 3s to turn on and SIM7500 takes about 15s
  // Press Arduino reset button if the module is still turning on and the board doesn't find it.
  // When the module is on it should communicate right after pressing reset
  // Software serial:
  modemSS.begin(115200); // Default SIM7000 shield baud rate
  Serial.println(F("Configuring to 9600 baud"));
  modemSS.println("AT+IPR=9600"); // Set baud rate
  delay(100); // Short pause to let the command run
  modemSS.begin(9600);
  if (! modem.begin(modemSS)) {
    Serial.println(F("Couldn't find modem"));
    while (1); // Don't proceed if it couldn't find the device
  // Hardware serial:
  modemSerial->begin(115200); // Default SIM7000 baud rate
  if (! modem.begin(*modemSerial)) {
    DEBUG_PRINTLN(F("Couldn't find SIM7000"));
  // The commented block of code below is an alternative that will find the module at 115200
  // Then switch it to 9600 without having to wait for the module to turn on and manually
  // press the reset button in order to establish communication. However, once the baud is set
  // this method will be much slower.
  modemSerial->begin(115200); // Default LTE shield baud rate
  modem.begin(*modemSerial); // Don't use if statement because an OK reply could be sent incorrectly at 115200 baud
  modem.setBaudrate(9600); // Set to 9600 baud
  modemSerial->begin(9600);
  if (!modem.begin(*modemSerial)) {
    while(1); // Don't proceed if it couldn't find the device
  type = modem.type();
  Serial.println(F("Modem is OK"));
  Serial.print(F("Found "));
  switch (type) {
    case SIM800L:
      Serial.println(F("SIM800L")); break;
    case SIM800H:
      Serial.println(F("SIM800H")); break;
    case SIM808_V1:
      Serial.println(F("SIM808 (v1)")); break;
    case SIM808_V2:
      Serial.println(F("SIM808 (v2)")); break;
    case SIM5320A:
      Serial.println(F("SIM5320A (American)")); break;
    case SIM5320E:
      Serial.println(F("SIM5320E (European)")); break;
    case SIM7000:
      Serial.println(F("SIM7000")); break;
    case SIM7070:
      Serial.println(F("SIM7070")); break;
    case SIM7500:
      Serial.println(F("SIM7500")); break;
    case SIM7600:
      Serial.println(F("SIM7600")); break;
    default:
      Serial.println(F("???")); break;
  // Print module IMEI number.
  uint8_t imeiLen = modem.getIMEI(imei);
  if (imeiLen > 0) {
    Serial.print("Module IMEI: "); Serial.println(imei);
  // Set modem to full functionality
  modem.setFunctionality(1); // AT+CFUN=1
  // Configure a GPRS APN, username, and password.
  // You might need to do this to access your network's GPRS/data
  // network.  Contact your provider for the exact APN, username,
  // and password values.  Username and password are optional and
  // can be removed, but APN is required.
  modem.setNetworkSettings(F("fast.t-mobile.com"));  //, F("your username"), F("your password"));
  //modem.setNetworkSettings(F("m2m.com.attz")); // For AT&T IoT SIM card
  //modem.setNetworkSettings(F("telstra.internet")); // For Telstra (Australia) SIM card - CAT-M1 (Band 28)
  //modem.setNetworkSettings(F("hologram")); // For Hologram SIM card
  // Optionally configure HTTP gets to follow redirects over SSL.
  // Default is not to follow SSL redirects, however if you uncomment
  // the following line then redirects over SSL will be followed.
  //modem.setHTTPSRedirect(true);
  // Other examples of some things you can set:
  modem.setPreferredMode(38); // Use LTE only, not 2G
  modem.setPreferredLTEMode(1); // Use LTE CAT-M only, not NB-IoT
  modem.setOperatingBand("CAT-M", 12); // AT&T uses band 12
//  modem.setOperatingBand("CAT-M", 13); // Verizon uses band 13
  modem.enableRTC(true);
  modem.enableSleepMode(true);
  modem.set_eDRX(1, 4, "0010");
  modem.enablePSM(true);
  // Set the network status LED blinking pattern while connected to a network (see AT+SLEDS command)
  modem.setNetLED(true, 2, 64, 3000); // on/off, mode, timer_on, timer_off
  modem.setNetLED(false); // Disable network status LED
  modemSerial->print("AT+CNMI=2,1\r\n");  // Set up the modem to send a +CMTI notification when an SMS is received
  Serial.println("Modem Ready");
char modemNotificationBuffer[64];  //for notifications from the modem
char smsBuffer[250];
char callerIDbuffer[32];  //we'll store the SMS sender number in here
int slot = 0;            //this will be the slot number of the SMS
  char* bufPtr = modemNotificationBuffer;    //handy buffer pointer
  if (modem.available())      //any data available from the modem?
    int charCount = 0;
    //Read the notification into modemInBuffer
    do  {
      *bufPtr = modem.read();
      Serial.write(*bufPtr);
      delay(1);
    } while ((*bufPtr++ != '\n') && (modem.available()) && (++charCount < (sizeof(modemNotificationBuffer)-1)));
    //Add a terminal NULL to the notification string
    *bufPtr = 0;
    //Scan the notification string for an SMS received notification.
    //  If it's an SMS message, we'll get the slot number in 'slot'
    if (1 == sscanf(modemNotificationBuffer, "+CMTI: " MODEM_PREF_SMS_STORAGE ",%d", &slot)) {
      Serial.print("slot: "); Serial.println(slot);
      // Retrieve SMS sender address/phone number.
      if (! modem.getSMSSender(slot, callerIDbuffer, 31)) {
        Serial.println("Didn't find SMS message in slot!");
      Serial.print(F("FROM: ")); Serial.println(callerIDbuffer);
      // Retrieve SMS value.
      uint16_t smslen;
      if (modem.readSMS(slot, smsBuffer, 250, &smslen)) { // pass in buffer and max len!
        Serial.println(smsBuffer);
        // OPTIONAL: Check for a magic password and do something special!
        // Maybe turn on a relay, send a reading only with this password,
        // or send GPS coordinates! Use your imagination!
        const char* magicPass = "Testing"; // You can create more magic passwords!
        if (strcmp(smsBuffer, magicPass) == 0) { // Check if strictly identical
          // Unlock the secret stash of chocolate!
          sendText("Treasure chest unlocked!");
          // Do stuff like digitalWrite(lockPin, HIGH); or something
          // Use your imagination!
        else if (strstr(smsBuffer, magicPass) != NULL) { // Only check if the magic password is somewhere in the text
          sendText("Opening secret door!");
          // Do stuff like digitalWrite(door, HIGH)
        else { // The text didn't contain the magic password!
          // Reply with normal sensor data!
          float sensorVal = analogRead(A0) * 1.123; // For testing
          char textMessage[100]; // Make sure this is long enough!
          char sensorBuff[16];
          dtostrf(sensorVal, 1, 2, sensorBuff); // float_val, min_width, digits_after_decimal, char_buffer
          strcpy(textMessage, "Sensor reading: ");
          strcat(textMessage, sensorBuff);
          sendText(textMessage);
// Send an SMS response
void sendText(const char* textMessage) {
  Serial.println("Sending reponse...");
  if (!modem.sendSMS(callerIDbuffer, textMessage)) {
    Serial.println(F("Failed"));
    Serial.println(F("Sent!"));
  // Delete the original message after it is processed.
  // Otherwise we will fill up all the slots and
  // then we won't be able to receive any more!
  if (modem.deleteSMS(slot)) {
    Serial.println(F("OK!"));
    Serial.print(F("Couldn't delete SMS in slot ")); Serial.println(slot);
    modem.print(F("AT+CMGD=?\r\n"));
Any advice appreciated
If I'm looking at the right section of the code, the problem is likely to be that one or more of the three conditions for terminating the while loop is causing premature termination of the C-string.
In the case of long messages continuing across a buffer boundary, I've found the Serial.peek() function, rather than Serial.read(), to be quite useful.
It does look like a buffer length problem.
The last condition only allows the loop to read sizeof(modemNotificationBuffer)-1 characters, which is 63.
If it sends a string like this:
then it is definitely going to terminate early.
Make the modemNotificationBuffer 120 or more characters and try it again.
Pete
I increased the size of the modemNotificationBuffer to 120 and no change, last character and quotation " still cut off. I have tried many different length words and phrases, 4 characters to 12, same problem. Looks to me like a "-1" may remove one character. But actually the last character and a double quote are removed.
Doesn't look like any of the three criteria could hit.
I opened an Issue on GitHub for this BotleticsSIM7000.h library too.
Your code is looking for "+CMTI: " in the response, but what I presume is example output in your msg #1 starts with "+CMGR: ". Either your code is looking for the wrong string, or that's not an example of the output.
Insert in front of this statement:
these two lines
          Serial.print("smslen = ");
          Serial.println(smslen);
and then post all the output that is produced, .
Pete
el_supremo,
Message sent was: Test message
Serial monitor output with your two suggested lines:
+CMTI: "SM",1
slot: 1
	---> AT+CMGF=1
	<--- OK
	---> AT+CSDH=1
	<--- OK
	---> AT+CMGR=1
+CMGR: "REC UNREAD","+172xxxxxxxx","","25/06/09,07:39:16-28",145,36,0,0,"+12063130004",145,12
	---> AT+CMGF=1
	<--- OK
	---> AT+CSDH=1
	<--- OK
	---> AT+CMGR=1
+CMGR: "REC READ","+172xxxxxxxx","","25/06/09,07:39:16-28",145,36,0,0,"+12063130004",145,12
"Test messag
smslen = 12
"Test messag
Sending reponse...
	---> AT+CMGF=1
	<--- OK
	---> AT+CMGS="+172xxxxxxxx"
	---> Sensor reading: 626.63
Failed
	---> AT+CMGF=1
	<--- OK
	---> AT+CMGD=001
	<--- OK
OK!
(Feels like this is a AdafruitFona library issue.)
I can't figure out where the quote is coming from in "Test messag
My guess is that the modem is sending "Test message" including the quotes but only reporting that the message is 12 bytes long.
The library then truncates the message to 12 bytes which leaves just "Test messag
Try sending the message "123456" and see what happens.
You may be right about it being the library.
Pete
