Here is a little piece of code I've put together to deal with the no float support in sprintf.
Arrch could you post your solution as code please??
Utility function for use in printing floats into buffers like sprintf(...
The library function dtostrf is the basis of this utility. It does a lot of work
in converting floats to strings but what makes it a bit irritating is that it needs
a buffer to write the float into which makes it very cumbersome in in-line code -
just rewrite the sprintf example below using dtostrf!
A collection of static char buffers is maintained in the function so that they are used
consequetively with each call. A single buffer cannot be used when the function is used
as a parameter to a call like sprintf in the example/test code below. This is simply because
the compiler writes the code so that all the calls to fs2 are made before passing the
results of the calls to the routine sprintf.
This function does hard work of cycling through the internal buffers. The default
number of buffers is 10 so a sprintf, for example, with more than 10 calls to fs2 will
overwrite the the beginning of the buffer. Avoid this by making a subsequent call to sprintf.
Please feel free to use this as you wish... I'm sure some enterprising coder will improve it :)
Alan Boother 2013/07/03
// float to string
char *f2s(float f, int p){
char * pBuff; // use to remember which part of the buffer to use for dtostrf
const int iSize = 10; // number of bufffers, one for each float before wrapping around
static char sBuff[iSize][20]; // space for 20 characters including NULL terminator for each float
static int iCount = 0; // keep a tab of next place in sBuff to use
pBuff = sBuff[iCount]; // use this buffer
if(iCount >= iSize -1){ // check for wrap
iCount = 0; // if wrapping start again and reset
else{
iCount++; // advance the counter
return dtostrf(f, 0, p, pBuff); // call the library function
And here is some test/sample code
// test/example code below
char sOut[200]; // big space for output
void setup() // test funtion in setup
float s0 = 0.1; // this one will be overwritten by s10
// with the current buffer in f2s of 10 floats
float s1 = 1.1;
float s2 = 2.1;
float s3 = 3.1;
float s4 = 4.1;
float s5 = 5.1;
float s6 = 6.1;
float s7 = 7.1;
float s8 = 8.1;
float s9 = 9.1;
float s10 = 10.1;
sprintf(sOut, "0: %s, 1:%s, 2:%s, 3:%s, 4:%s, 5:%s, 6:%s, 7:%s, 8:%s, 9:%s, 10:%s", f2s(s0, 4), f2s(s1, 4), f2s(s2, 4), f2s(s3, 4), f2s(s4, 4), f2s(s5, 4), f2s(s6, 4), f2s(s7, 4), f2s(s8, 4), f2s(s9, 4), f2s(s10, 4));
Serial.println(sOut);
Serial.println("The output above has overwritten 0:with 10:'s value");
sprintf(sOut, "0: %s, 1:%s, 2:%s, 3:%s, 4:%s, 5:%s, 6:%s, 7:%s, 8:%s, 9:%s", f2s(s0, 4), f2s(s1, 4), f2s(s2, 4), f2s(s3, 4), f2s(s4, 4), f2s(s5, 4), f2s(s6, 4), f2s(s7, 4), f2s(s8, 4), f2s(s9, 4));
Serial.println("The output above only needs 10 buffers so overwriting hasn't occured");
void loop(){
