Socket Communication Between Arduino Mega and Laptop without Router
Assume we have a setup involving an Arduino Mega with an Ethernet Shield and a laptop. Currently, the server code is running on the laptop, and client code on the Arduino Mega.
My main concern revolves around the necessity of a router for successful socket communication. I don't have a router at the moment, and I'm hesitant to invest in one due to cost constraints. Could you advise whether socket communication between the Arduino Mega and the laptop would still be possible without a router, given the setup I described?
yes. use a crossed cable
Or a Layer 2 Ethernet switch.
If cost is that much of a concern, would a serial connection be feasible and skip the ethernet shield altogether?
Are you sure? Have you tried this before
A router does what its name says: routing signals
You have asked for a detail.
My experience is: as soon as the overview is given what the whole project is
and what the final purpose of the dataexchange is different solutions can be suggested
best regards Stefan
I want to learn socket programming and HTTP protocol through practical applications using an Arduino board via ethernet module.
I can purchase ethernet shield and cross over LAN cable However, due to budget constraints, investing in a router is currently beyond my means
Without a route to act as a DHCP Server, you'll need to manually assign IP addresses, on the same subnet, to both the Ethernet shield and laptop.
Yes, should work..
Will have to set your addresses manually..
Might not need a cross over cable with modern network interfaces..
Might even be able to get some internet to it using internet connection sharing, was added in windows 98, still exists, never really worked perfect, but it is free..
happy holidays, good luck.. ~q
I connect the Ethernet shield directly to a computer all the time. I don't even use a crossed cable. but on the computer I set network sharing so the computer acts as router
it will work if you do everything right.
Set a fixed IP on your ethernet adapter on the laptop
Set a fixed IP on your Mega
IP & Subnet definitions must fit together.
Otherwise it will not work.
If you can ping the Mega from the laptop, you should be able to do a socket communication also.
As already mentioned, on very old laptops you might need a crosspatch cable.
