Hi !
I'm trying to convert my projet to a PCB with SMD components.
In my project, I have to read a 1200 bauds TTL signal form household energy meter (Linky, that green box used in France to know how much enegy we drawn from network) .
The TTL signal is put a correct voltage using an optocoupler.
Using an Arduino Mini on a breadbord and SoftwareSerial on pin A2/16 works great.
But, on my custom PCB with an Atmega328P-AU (same chip as Arduino mini), the same signal wired to the same pin doesn't work at all.
There is absolutely no output from SofwareSerial using the same sketch.
If I place an LED across pin A2/16 and GND, the led is blinking at the beat of the TTL signal.
At this point, I think I'm missing something about bootloader, frequency, ...
I tried to configure fuses the same way they are on the Arduino Mini, but i'm not sure of my attempts.
What do you think about my problem, what would you look at to understand the issue ?
