Software serial - making it wait
I am trying to make a Software serial "receiver" wait around until data is present if its not already there to be read.
Probably, in practice, use software serial , but anyhow, was thinking along the lines of:
I realise its blocking , but thats not an issue:
  Serial.begin (19200);
  bool A = true;
  //  do other stuff other  setup type stuff
  // related to getting inital setup parameters from another processor :
  if (Serial.available > 0)
    READIT();
    A = false;
  while ((A == true) && (Serial.available == 0))
    delay(50);
      READIT();
      A = false;
}// end setup
void READIT()
  //read data from serial port.
seems a bit "clunky", so wondered if there was a more elegant route ?
That's SoftwareSerial you want?
Edit:
#include <SoftwareSerial.h>
SoftwareSerial softSerial(2,3);
  softSerial.begin(19200);
  if(softSerial.available()) {
    // do your softSerial.read stuff
Robin's updated serial input basics comes to mind. Just adjust it to use a SoftwareSerial instance.
If you need it to be blocking
while (newData == false)
  // one of Robin's the receive functions
Yep I’m happy with software serial , it’s reading the data , but making it hang around if the data is not there .
I’ve looked at serial basics , doesn’t cover this situation.
That is what the code I posted does. It waits around forever until something comes in on the SoftwareSerial port. I set my example for pins 2 and 3.
But if there no data when ‘serial.aveilable ‘ runs then it moves onto the next instruction.
If you notice I have it in void setup() so only one shot .
** aha !! **
So that will stay at that point and move on if >0 or if was > 0 when it executed . That’s much neater thx.
