I am working on a Micro and trying to establish a SoftwareSerial port. I up load the Software Serial examplein the Arduino IDE, but it does not work. The code
is below. Why is it not working??? I know that the Micro is based off of the Atmeg32u4 which is the same chip as the Arduino Leonardo and have taken care to use the correct pins according to what the Leonardo needs, but I still cannot get it to work. Any help here would be greatly appreciated.
Software serial multple serial test
Receives from the hardware serial, sends to software serial.
Receives from software serial, sends to hardware serial.
The circuit:
- RX is digital pin 10 (connect to TX of other device)
- TX is digital pin 11 (connect to RX of other device)
Note:
Not all pins on the Mega and Mega 2560 support change interrupts,
so only the following can be used for RX:
10, 11, 12, 13, 50, 51, 52, 53, 62, 63, 64, 65, 66, 67, 68, 69
Not all pins on the Leonardo support change interrupts,
8, 9, 10, 11, 14 (MISO), 15 (SCK), 16 (MOSI).
created back in the mists of time
modified 25 May 2012
by Tom Igoe
based on Mikal Hart’s example
This example code is in the public domain.
#include <SoftwareSerial.h>
SoftwareSerial mySerial(10, 11); // RX, TX
Serial.begin(57600);
while (!Serial) {
Serial.println(“Waiting”); // wait for serial port to connect. Needed for Leonardo only
Serial.println(“Goodnight moon!”);
// set the data rate for the SoftwareSerial port
mySerial.begin(57600);
Serial.println(“1”);
mySerial.println(“Hello, world?”);
Serial.println(“2”);
void loop() // run over and over
//Serial.println(“3”);
if (mySerial.available())
Serial.write(mySerial.read());
if (Serial.available())
mySerial.write(Serial.read());
